08-10-2005, 01:17 PM | #1 | ||
I.B.S is a pain in d'***
Old mate of mine told me about a trick he would use on his old Clevo. I think he is having a lend of me, but if anyone else has heard of this let me know.
Apparently a quick and easy way of cleaning out the carby and valves and to help re-seat the rings is to follow this. Warm up engine Remove airfilter Sprinkle in to carby a couple of handfulls of AJAX cleaning powder! Now am i being sucked in or is this and "old trick" It does sound like it may help, but............. :monkes:
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then Last edited by Thunder; 08-10-2005 at 02:33 PM. |
08-10-2005, 01:23 PM | #2 | ||
windsor user
sounds pretty dodgy to me, not something id be doing if it was my engine.........
08-10-2005, 07:15 PM | #3 | ||
now now, remember what they did on Myth Busters? mothballs anyone?
08-10-2005, 07:25 PM | #4 | |||
335 S/C GT: The new KING of Australian made performance cars.. |
08-10-2005, 07:34 PM | #5 | ||
In the Forced 'lane
AJAX is not only abrasive but it's caustic too. Who in their right mind would
put it in their engine?
XE S-Pack 4 Runner XH11 Longreach |
09-10-2005, 01:22 AM | #6 | ||
Digging for avatar
Then you could throw some water in and watch the pretty bubbles blow out the zorst.
was extinct but got better. |
09-10-2005, 01:50 AM | #7 | ||
She needs premium dude...
I've heard of this before aswell. Apparenty it helps to deglaze the bores and improve compression. Also heard auto trans fluid does the same thing.
09-10-2005, 03:11 AM | #8 | ||
Has Blue Blood
Yes its an old trick for bedding in rings and deglazing bores ! Doesnt hurt the motor at all ! One of my mates had his big block sh1trolet rebuilt by a reputible mechanic and it did nothing but smoke and use heaps of oil, even after well and truely run in ! The mechanic gave up in the end and refused to do any more unless he started seeing more money ! We ended up doing this trick 3 times over a couple of weeks and after the third time it ran perfectly , and is still running strong today . if you just want to clean the carbon deposits of your valves and pistons , while the engine is running misting some water into the intake with a squirt bottle now and then will help.
Havent heard the Auto tranz fluid thing but !
Real cars dont wear bowties I'm not arrogent , Just superior
09-10-2005, 07:25 AM | #9 | |||
Ford Fanatic
Everyone is entitled to my Opinion 2007 Territory TX SY RWD Ego |
09-10-2005, 11:32 AM | #10 | ||
Well, its a bit mixed as to opinions. From what i have heard now, i am maybe thinking of trying out. But still unsure. The 302 clevo does need a good cleran and so does the Holley 650 vac sec but..................
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then |
09-10-2005, 05:12 PM | #11 | ||
burn out king
i have used a mix of ajax and water to deglaze an xf worked just dont go overbored bring the revs up and just tip a little in at a time.
09-10-2005, 05:26 PM | #12 | ||
Hoon On The Rise
One year at bathurst, a motor was run in over night by using ajax to bed the rings in.... Brock was the culprit, but i may be wrong...
yes its true. And on that for crazy things, noisy diff, or stiff manual gearbox??? Splash of AUTO oil in them will fix that right up....
Stomp 'n' Steer FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
09-10-2005, 06:20 PM | #13 | ||
Noisy diff gears? Chuck a banana skin in there.
10-10-2005, 08:47 AM | #14 | |||
10-10-2005, 02:47 PM | #15 | ||
The one and only
I've used the water mist to clean combustion chambers on old cars. I heard brake fluid works and Diesel on UL cars.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
10-10-2005, 02:54 PM | #16 | ||
I believe the correct way is to mix Ajax and petrol to a runny watery paste, and pour it down the carby. It is more commonly referred to as "hone in a can"
Another way to stop an engine smoking, is to run about 1-2 litres of ATF in a full tank, and when its just about gone, run a few cups of glass cleaner through the carb, works a treat..... Just like oven cleaner is brilliant for removing stickers/pin stripes.... |
10-10-2005, 05:53 PM | #17 | ||
I tried using brake fluid on my KB Laser, it didn't stop it blowing smoke, but it did seem to run a bit better afterwards... I'd never try it on the EA though.
As for AJAX, I reckon I'll try it on my brothers Datsun 120Y :
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG RIP: EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007 |
10-10-2005, 09:43 PM | #18 | ||
Hoon On The Rise
The other good trick i use is cross leads 2 and 3 on ANY motor to clean out the carby.....
Works a treat...
11-10-2005, 08:49 AM | #19 | |||
Has Blue Blood
11-10-2005, 09:47 AM | #20 | |||
Ford Fanatic
Yes I did. There is no way ajax or any other kind of oil treatment/injector treatment could possibly have an affect on the valve i refer to. It is usually attached to the inlet manifold and has a breather tube to the crankcase to allow the crankcase to breath. even if the valve was stuck cleaners could not touch it. And its about an $8.00 part that is easily missed.
11-10-2005, 09:50 AM | #21 | ||
Anyone done the AJAX trick to an EFI car? EA onwards... ?
11-10-2005, 12:26 PM | #22 | |||
The one and only
11-10-2005, 02:51 PM | #23 | |||
Has Blue Blood
11-10-2005, 02:52 PM | #24 | |||
Has Blue Blood
it wouldnt effect the oxygen sensor in any way !
11-10-2005, 03:02 PM | #25 | ||
So if i mixed a petrol/ajax solution and sprayed into my throtal body while im slightly revving it shouldnt damage anything?
11-10-2005, 03:32 PM | #26 | |||
11-10-2005, 03:40 PM | #27 | ||
Causes backfire out of the carbie to dislodge soemthing blocked in there. As there is a spark in the chamber whilst the air valve is open, it detonates and bam! out of the intake
11-10-2005, 03:41 PM | #28 | |||
Hoon On The Rise
The backfiring blows out all the crap in the carby and manifold. Cross the leads (at dizzy cap), and run the engine a few times, and give ti some... Then cross the leads back to original. makes a big difference in performance. DONT do it on an EFI car!!!!!!!!!!!!!!!!!!!
11-10-2005, 05:10 PM | #29 | ||
Anyone done the AJAX trick to an EFI engine?
11-10-2005, 07:19 PM | #30 | ||
its not a!
Reminds me of an article in the Australian Dirt Bike mag they said you could add V8vege juice into he fuel mix to align molecules +more scientific mumbo, and would clean out the carbie and boost octane...
Nobody knowticed it was the april edition
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
