Anyone sporting rear window louvers on their coupe ? I have a set of what I was told where Goss Factory louvers (?) which I'm considering installing. My concern it putting holes in the roof and sail panel to attachment as well as how they look installed. Anyone have pics of them installed ?
Thanks Leon |
BF XR8 Ute
![]() Join Date: Jun 2013
Cheers Geoff _____________ HIS 2006 BF MKII XR8 Ute,Shockwave Blue. HERS New One Coming Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont,LX Focus Greetings Earthlings. |
Got em on both our cars. Hoping to find one for the 3rd too. Mind you, ours are aftermarket aungers. Don't need to drill the roof. See if I have any pics from the back of the cars. I personally like the look but I am a bit old school
RPO 77
![]() these are mine had/have the aungers - they kept blowing off - at least the original bolt on and stay there - if you do the hinges properly they can be made so they will never leak if that is your concern
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! ![]() ![]() |
#5 | |||
RPO 77
I like the sound of your nut washer - are you able to Post a pic of that setup? - Don't worry found it Google my friend!
I use a captured nut with medium set liquid thread seal on the hinge On the lower pass through bolts I use a large epdm commercial roofing washer
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! ![]() ![]() Last edited by CJR09; 21-12-2013 at 08:55 AM. |
RPO 77
Looking at those rubber nut inserts - they could be the go on the lower pas through bolts as well
Take the rubber nut insert - delete the Internal thread and use a the washer and wing nut as per oem to clamp it tight creating the seal from underneath
I was thinkin of using a rubber grommet on the bottom.
