Old 08-08-2011, 09:47 PM   #1
Bunky Twincam
Default Parts advice needed for MK1 escort for motorsport
Hello all,
I am about to get my MK1 twincam ready for some motor sport and need some advice on what to use and where to get it for the below. I am doing some jymkhanas and track days.
Heavy duty front sway bar
Vented front disc conversion
Some sort of racing seats (pair)
LSD conversion
Full nolethane bush set
Bunky Twincam is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 10:28 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Parts advice needed for MK1 escort for motorsport
welcome to the forums
might help if you post where you are from, you may get some referrals
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2011, 10:43 AM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
If you want to get some good advice - plenty of info here
http://www.rsmotorsport.com.au/
cheers
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2011, 07:29 PM   #4
Neale
Neale's Avatar
this forum has heaps of info aswell
http://www.classic-ford.org/forum/default.asp
Also Smcka sells alot of go fast bits & has experience with building escorts so he know what hes talking about.
His webpage is:- http://classicescortparts.com.au/
Also if your interested in motorsport, check the rules at th CAMS webpage to make sure it you dont do a mod that you may have to remove.
http://www.cams.com.au/en/Sport/CAMS...tor_Sport.aspx
Neale is offline   Reply With Quote Multi-Quote with this Post
