11-06-2015, 05:13 PM | #31 | ||
hi easyboss,
i wrote that post a while ago, give me a ring on 0428746617 and ill try to explain........... only just realized you are in NZ im in AU, so youd have to ring +61428746617 (i think) Last edited by XYwagonAU; 11-06-2015 at 05:31 PM. |
11-06-2015, 05:28 PM | #32 | ||
you can access the adjustment without taking the disc off
to tighten you turn clockwise- but because of where the access 'window' is, you have to turn it differently on each side, the hole to access adjustment has rubber grommet over it the adjusting wheel has lumpy bits (like castellations) you push the wheel with a screw driver- either levering toward you or pushing away - as wheel is perpendicular to disc (horizontal) get a torch and try to see what is going on it there.. im not sure but i think i jacked both rear wheels off the ground, put vehicle in neutral, handbrake off, turn one of the adjustment screws a bit / then test- you want the brake to come on by 4th click apparently btw - im definitely not a mechanic (any only tried this on AU wagon - disc brakes no IRS) if you dont get any joy you can take disc off then you will see what is going on........... Last edited by XYwagonAU; 11-06-2015 at 05:35 PM. |
11-06-2015, 05:32 PM | #33 | ||
This is fantastic information. My handbrake requires adjustment too...saves me starting a new thread now.
Cheers for the write up/info fellas.
My Ride... 2005 BA2 XR6 Magnet Ute. |
11-06-2015, 05:35 PM | #34 | ||
Matakana NZ
^^^ thanks I'm in NZ, were are you, guessing you cant remember what direction for what side, so I might have to take on drum off to work it out, maybe not a bad thing as I could also check out the shoe wear
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
11-06-2015, 06:14 PM | #35 | ||
clockwise to tighten - if you imagine the adjusting wheel from above - see old post .......
"-left/ drivers side, tighten by levering toward yourself - right side, tighten by pushing away" Last edited by XYwagonAU; 11-06-2015 at 06:21 PM. |
11-06-2015, 06:41 PM | #36 | ||
http://www.fordforums.com.au/showthread.php?t=11418260
found this pic on forum..........courtesy - "phildo" also first step is to turn the disc/drum around so that you can find adjustment screw....... |
12-06-2015, 05:32 PM | #37 | ||
I adjusted the handbrake cable inside the ute today and it only just holds the vehicle so tomorrow I'm gonna adjust it by removing the rear wheels. Hoping I can get a screwdriver in the inspection hole and adjust it like that. If not I'll remove the discs and adjust it that way.so it's clockwise for both left and right sides?
12-06-2015, 06:46 PM | #38 | ||
hi revcore,
Im actually wondering if the clockwise thing is true I remember adjusting on left and right side is different put handbrake on 2 clicks- then make adjustment i would try levering wheel toward you drivers side pushing wheel away from yourself passenger side if handbrake is on it should tighten up quicker get a torch to have a look through hole cheers |
13-06-2015, 12:32 PM | #39 | ||
FG XR50 TURBO
I have tried 2x attempts adjusting the handbrake on my AU XR8 and it's still the same as before
here is a shot how the handbrake leaver is, is this too high ?? and another thing it doesn't hold in any gear besides Park ?? cheers Dean |
13-06-2015, 12:46 PM | #40 | ||
blu is yours a ute /wagon or sedan?
not sure if they are different but wagon doesnt have irs, handbrake is like a drum brake inside a disc brake so maybe take the disc off, check lining on handbrake check spring etc, clean it out there is a picture below shows it inside ps you want to keep adjusting until you cant turn disc around, then make sure it moves smooth when handbrake off (might have to back off adjustment) good luck, btw im not a mechanic so take with grain of salt. cheers Last edited by XYwagonAU; 13-06-2015 at 12:58 PM. Reason: add a bit |
13-06-2015, 03:07 PM | #41 | ||
FG XR50 TURBO
The XR8 is a sedan IRS
15-09-2015, 07:29 PM | #42 | ||
heya woosha you did this ^^^ on a BA model ? i ended up pulling the rotors of as there is no way to adjust through the little hole you spoke of when i pulled the rotors off the hole did not line up with the adjusting nut
16-03-2017, 02:02 AM | #43 | ||
Yeah the hole does not line up well, you cant really see the adjustment wheel. But if you use a bent small screwdriver you can do it by feel - not easy.
I took off rotor, and worked out (by putting rotor back in reverse) where to drill a hole for adjustment with the rotor on. It is not hard to drill a 10mm hole in the rotor (in area clear of holes) using a good quality high speed steel drill. Go 14mm if you have one. Dean it only holds in park as the handbrake is not doing anything, it's the park lock pin working. |
19-03-2017, 10:20 AM | #44 | ||
Next upgraded Mk1 Leopard
Thread mine
UK Mind you mine needs a tighten up too
20-03-2017, 11:25 AM | #45 | ||
The only AU out of my four that has a handbrake that works well is the ute. The wagon one specially is useless. One day i'll give this a go.
01-04-2024, 03:40 PM | #46 | ||
An oldie but a goodie - thanks Whoosha. Just used the original post to adjust mine. Shame the adjusters go different directions to tighten on each side. Easy on the passenger side but more difficult on the driver's side. Great handbrake now
Cheers Adrian |
