Old 18-01-2024, 10:35 PM   #1
Tonz
Default opera(?) window insulation
the little windows behind the ute doors.
My previous ute had a load of sound deadening all through the cabin and after buying this new one same thing needs to happen.
That poxy window was always the bug. Dont know if it was the rubber seal or the glass, so my thinking is remove everything, run a thin bead of silicone around the edge of metal gap, refit rubber, clean up any mess then instead of glass being refitted a thick piece of acrylic/perspex
good or bad?
Tonz is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2024, 10:55 PM   #2
Itsme
Experienced Member
Itsme's Avatar
Default Re: opera(?) window insulation
Leave the window as is, Acrylic perspex will cheapen the look of the ute, also perspex is prone to marks and scratches over time with washing of the ute.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2024, 10:56 PM   #3
Tonz
what about extra silicone or similar?
Old 19-01-2024, 04:23 PM   #4
Luxury cars often now have acoustic glass to their windows. This is laminated glass with a thicker media between the two pieces. It might be that a skilled glazier could re-cut a couple of BMW or Benz side windows to fill these places.
I presume you are adding a bonded soundproofing sheet to the panel below this glazing, in addition to using acoustic wool in the cavity.
Old 19-01-2024, 04:25 PM   #5
Tonz
have 3 boxes of Car builders sound deadening ready but a few other jobs first.
