Hi All I have a MK2 2 door that the ID plate is missing. I have the body number CM23651B (pretty sure this is correct). Can anyone assist with identification. Thanks Matt
formerly ford3000gt
I'd suggest that that is an engine number, but the C would have to be a G for 1967, with the M being the month, which I don't know off the top of my head.
Current ride: '83 Mk.3 Capri, 2.8i, 5-spd |
#4 | |||
formerly ford3000gt
It is stamped into the right hand strut tower. The letter and number sequence matches my series 2 GT, but it starts with CN. I have attached a pic of the number on my original post. Thanks for the replies.
Matt |
Thats the engine number on the strut tower cm was
a standard engine cn a gt engine the number you need is on the radiator support panel |
Thanks chappy60, You learn something new every day. I looked on the radiator support panel first, but didn't see it. I will have a better look and see if I can find it. Thanks Matt
standing at the front of the car it will be to
the right of the bonnet catch on rare occasions you might have to unscrew the grill on top and pull it back a bit to see it |
So it turns out the radiator support panel has previously been replaced. The replacement panel didn't get the body number stamped into it. Any suggestions on what I can do for a body number when it comes time to register it (in QLD)?
formerly ford3000gt
Perhaps just check with the registration authority, Queensland Transport, as they are the responsible authority in your State!
if you have the old rego put it into the qld
rego app you might get lucky with a cm engine number sounds like its around a 68 model was the car ever on club rego |
#12 | ||
I don't have any previous rego details unfortunately. I purchased it as a rolling body along with a heap of GT parts from south of Sydney about 7 years ago. I was thinking maybe a late 68 or 69, as it's a series 2 but had the smaller id plate on the inner wing. I will go into the local Ford dealer here in Toowoomba with the engine number and see if they can find any details.
Thanks for the replies, Matt |
