Hi all,
I have a LS focus Zetec 2.0 petrol Auto. My economy is consistently around 12.8L/100kms. This seems really high or is it normal for city driving? what are other people getting? |
VFII SS UTE
i would say that's high..
wife's suzuki 1.5ltr gets around 6.8.. my ute 6.2ltr gets 13.3...
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
My LS Ghia averages 10.9
Seems high - even for city use. What is your average speed ??
My wife's Mazda 6 (2.3 petrol, auto 5 speed) gets 8.9 in city driving (av speed 40 kph) |
Just checked....34kmh....10.4lt/100
If thats too high what can i do about it....change the oxy sensors? any suggestions
Seems like everyone is getting significantly better economy..... any idea what can cause this? the car runs fine, has no codes. i have replaced the temp sensor and thermostat, pcv valve and hose, also the throttle body. haven't done the o2 sensors as the live data scan shows sensor 1 voltage fluctuating as normal
open to suggestions. |
#9 | |||
I’m up in FNQ so my ac is permanently on. My car averages 8-8.6, if I take it on a run that goes down to below 7. I’d say you have a problem
#12 | ||
My car is manual. It is actually a LT .
#13 | ||
my car is auto
#14 | ||
My Fiesta St 1.5 turbo is averaging 6.5 litres per 100 in urban but is a manual.
Aside from checking spark plugs and gaps, do you have any strong fuel smell outside. May be a leak to vacuum seal that can cause fuel consumption
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
#15 | ||
My wife had a LS auto a few years ago, it was regularly serviced and that did around 10, it could never get near the manual car fuel consumption.
I’d be checking air filter, and perhaps a throttle body clean |
#16 | |||
Rob
If you provide your ave speed that should provide a good indication of the type of driving and give a more accurate comparison.
UA2 TREND 4WD BI TURBO |
#17 | |||
there is no fuel smell, car runs and drives fine doesn't feel down on power, the plugs are ngk iridium and were changed about 60k kms ago, going by the service receipts when i bought it (they should last at least 100k kms) they look fine. the air filter was changed less than 5k kms ago when i did a service Last edited by auc-05l; 28-11-2021 at 01:21 PM. |
#18 | |||
Rob
Do you do a lot of short trips? Modern ecu's will run quite rich when the car is cold, and short trips and slow speeds will contribute to higher than ave fuel consumption.
#19 | ||
Based off our LT and your average speed, it sounds pretty right. That is a very low average speed. And the autos are not known for great economy.
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
#20 | ||
I would tend to agree with the last two posts, sounds like for kind of usage the cars getting, the consumption you have would be about right. You seem to have done most things.
#21 | ||
I don't think it is unreasonable. The economy varies hugely depending on the driving for me.
For example, I drive the car to a train station 10km away each day and it gets 11L per 100. However, when I left that job and drive 30mins using mostly freeways, its now roughly 8L per 100. |
#22 | ||
It’s about right. I had an LV Focus auto for 9 years. Average fuel consumption over that time was 11.5L/100km (by recording litres of fuel and km travelled each fill, over 73,000km of mostly city driving.
It was serviced on schedule and did have new Oxy sensors at one point - they made it feel peppier but didn’t change the fuel consumption. |
#23 | ||
The only comment I would make is that the thermostat is critical. In my posts on the LS focus in this forum, I found the thermostat was opening at about 40 degrees C. I replaced the whole assembly with a new part.
The new thermo opened at about 85 deg C. This fixed the problem, but short runs in a cold climate destroys any sensible Fuel consumption figures. Recently, I have become worried that the thermo is opening at lower temperatures, AGAIN! It is taking about 10Km of driving to reach its stable operating temperature. Should be about 5 to 6 Km. I will check it again; it is a pain to get to the thermo. If it is faulty, I will replace only the thermostat; not the whole assembly. The car is due to go for service soon. I will get the air inlet hose checked as well. The car over-revs at startup and this is often caused by a split air inlet hose. See my posts on this subject. |
#24 | ||
Thanks all for the comments. Aside from the poor economy the car was awesome, but is now sold. Replaced with a diesel vw golf which does 7L/100kms doing the same trip (boot is no where near as big tho). Cheers
