Hi Everyone.
I've owned my Escort for Five years now and since taking her off the road she has been stripped and sitting in the shed for over Four years now. I think it's time to start on her but I dont know how to begin. Help, I live on the Northside of Brisbane and would like some contacts for Parts and people who I can talk too. Regards Ian |
Over Thinker
I would be interested to drop by and help some saturdays
like the two door escorts ..owned a mk 1 then a mk 2 I can help with mechanicals what you got in mind for it if its totally stripped you start at the body if its too rusty scrap it as for parts what type of parts ford escort wreckers at boondall is a start rest find on gumtree ebay or online .just depends most of the rubber may have perished how is the trimming /door cards No hope with wiring auto electrics sorry
My car goes Brumm Brumm Last edited by dirty hands; 18-03-2015 at 07:24 PM. |
5 users like this post: |
Thanks for you reply, i live at Burpengary so it would be great to catch up and show you my car. I'll have to make room in my shed first and clear around the car. I have a lot of parts as i bought a Mark 2 and stripped it down for the 2Lt motor and running gear.
Your car looks greatand thats the look i have in mind for my car with the bubble arches. Whats involved in removing the front wings?
Over Thinker
iancramb - just up the highway 14 minutes away from me
that will work mark 2 as a parts car ....rest does sound interesting pop up a list of what you need as you sort through it bet it has rust somewhere ..dont even think to paint it kermit green
My car goes Brumm Brumm |
Over Thinker
let us know its codes if you can
this list inst that helpfull --- reviews and specs at the bottom is interesting reading http://www.uniquecarsandparts.com.au...tification.htm ford australia colours http://www.uniquecarsandparts.com.au...ompany_A-L.php
My car goes Brumm Brumm Last edited by dirty hands; 19-03-2015 at 12:01 PM. |
Not green , it will be Orange one day. Not much rust at all and fairly straight as well. Just some under the heater box and spare wheel well, with the drives side A pillar the worst that i can see untill the paint get stripped off.
The pillars are available new as exterior skins. the frame behind is usually OK if just a bit pitted.
Removing the front guards is a bit of a trial but depending on how they are fixed on you might be lucky. Get yourself a long spot weld drill of about 8mm wire wheel in grinder the paint away from the seams across the top and drill out the welds all bar one at this stage, then climb underneath and address the front seam spot welds which may be easier to cut away and replace with new metal due to their angle. the guard mat have a few spots along the rear edge against the pillar so invest in some time to remove the doors. a 8mm punch chisel and a die grinder is useful here. Some have had good luck with the pin removal tools some haven't. Finally grind away the lower strip weld at the base of the rear lower 1/4, then finish off witht he last top weld. However if yours has been replaced after an accident at some stage like one of mine its probably easier to cut it away. So decide to cut either the guard or the guard support. If the guard is a good one cut the support and replace later like this ![]() JP |
Over Thinker
orange should pop
when you get started you move this build to the project cars forum hope you like welding when you stat to referb body parts pics are good as a reference point only found a uk supplier so far http://www.motorsport-tools.com/ford...=asc&order=sku
My car goes Brumm Brumm Last edited by dirty hands; 20-03-2015 at 01:05 AM. |
try smcka (google search)for local parts, good guy good prices and local.
JP |
Tippy-tronic Free Zone
smcka - Steve Mackay
http://smckaperformance.com.au/ |
#13 | ||
Over Thinker
bad news here
web page says closing down http://smckaperformance.com.au/ We are closing down and have limited stock left. What ever is showing on the website is what we have left and anything out of stock will not be replaced
#14 | |||
#15 | |||
#16 | |||
#17 | ||
Over Thinker
no idea why didnt that second link stay working
#18 | ||
What Models is your 2 door? if its not a "Sport" and has the square headlights I would start by getting a round headlight grill and front Quarter bumpers.
some like the RS2000 look But I Prefer the square grill with a set of classic Hella Rally spot lights What Engine do you plan?
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
#19 | |||
#20 | |||
http://yesterford.com/
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end. ![]() |
#21 | ||
The demise of Smcka will hinder a few restos for a while bur hopefully someone will fill the gap...even thought of importing parts myself but my other business is doing pretty well and it more of a sure bet....Escorts are running out fast and customers are limited.
The 75 model is the one to have as it has all the mk 2 suspension as well as the large strut tops to fit capri struts...highly recommended mod as it drops the front no end. After 15 years of pulling apart Escorts, this year ive decided to learn how to weld and put them back together again. Im picking up my own project today, so pretty excited. |
