#31 | ||
Formerly ST170ish
Sweet lookin fat ***!
Nice work Koops |
#32 | ||
74xbkoop
Hi Again,
Sorry its been so long since the last post. Have been flat out with work. Thanks for the comments guys and Doc the colour is a pearl metalic. Back to the build. After I fitted the sil it was time to refit the door lock panel correctly (not slanted inwards like previously) ![]() ![]() Im going to post numerous small sections as the system logs me off and I loose everything before I get to post it. (Bloody computers) |
#33 | ||
74xbkoop
The side boot panel was also removed to be replaced.
![]() The replacement panel usual was crap so I made a new one. ![]() ![]() I also had to remove and rebuild this panel. Dont have any photos of this one finished. ![]() |
#34 | ||
74xbkoop
Then there was a lot of test fitting of the wheel tub and quater. Found out there was a lot to repair on the tub and a lot of adjustments.
![]() ![]() ![]() There was a lot of hours spent repairing the tub to get it to fit to the guard and getting it all to align. |
#35 | ||
74xbkoop
After having the quater on and off making tweeks to alignment for what seemed 100 times It was finally fitted and rewelded back on. The alignment was well worth all the effort.
![]() ![]() ![]() ![]() ![]() The lower rear window section fitted at the same time. ![]() Last edited by 74xbkoop; 18-08-2012 at 04:39 PM. |
#36 | ||
74xbkoop
Now was the time to sort out the mess on the join of the roof and quater.
![]() This section was cut out and I made a new fill section to weld in. ![]() ![]() After being fully welded slowly cleaned up the welds. ![]() ![]() ![]() ![]() |
#37 | ||
Awesome work mate.
Cheers Ryan
XA Falcon 500 Hardtop Build Thread |
#38 | ||
74xbkoop
The boot rubber channel was then replaced.
![]() ![]() ![]() And this corner repaired. ![]() |
#39 | ||
74xbkoop
The seam between the rear beaver panel and boot was also rusted. Cutting it out was the next job
![]() ![]() Then makup the outer section. ![]() ![]() ![]() ![]() |
#40 | ||
74xbkoop
Gradually moving around the car. The lower section behind the rear wheel was cut out and replaced as well as a new inner boot pane made for htis side as well.
#41 | ||
74xbkoop
Next was removing the RHS sil and rusted sections. Support rail was fitted the same as the other side and new sil fitted. all internal panels repaired. Unfortunately not may photos of this part recovered.
![]() ![]() ![]() The wheels had turned up. I could not wait, Had to put one on to see how they looked. ![]() Very happy. ![]() |
#42 | ||
74xbkoop
The center roof arial hole was filled.
![]() The rear bumper was fitted to check alignment. ![]() And had to rebuild the RH corner of the rear quater to make them even. ![]() ![]() Started to file finish the body section. ![]() Doors and guards fitted to check alignment. Side vents fitted. More Panel work. ![]() ![]() |
#43 | ||
74xbkoop
Once all the file finishing was finished. It was taken back to the booth for coating in high fill.
![]() ![]() ![]() ![]() Reassembled again ![]() ![]() Then loaded back up for the trip back home. ![]() |
#44 | ||
74xbkoop
After getting it back home the replacement drivers side door was repaired. Some rust in the bottom and a new lock section was made and fitted.
#45 | ||
74xbkoop
Now it was time to tackle the engine bay.
![]() With everything removed it was time to repair, Fill holes, remove anything not needed ![]() ![]() ![]() ![]() ![]() ![]() |
#46 | ||
Clevo power!
Awesome work! The transformation is just unbelievable. And I love the colour, very nice beast
The beast: XB coupe, 302, manual all the way! Fixing up thread The purple monster, daily BA XR6 turbo. Scale Lego Technic XB Coupe with working bits! Build thread |
#47 | ||
Regular Yobbo
Now thats a rebuild!!
![]() ![]() "I BLEED BLUE " QLD number plate....V8 COUPE !!! for sale,make a offer! |
#48 | ||
top work. very impressive
#49 | ||
74xbkoop
Thanks for the comments guys. Will get a chance to post some more in a couple of weeks. Flat out traveling with work at the moment. Back soon.
#50 | ||
Shockwave
Colour me gobsmacked..
![]() ![]() Has to be some of the most meticulous work I have ever seen, can't believe you even re-used that rear quarter panel. I can see why the end result is just awesome. Hey, if I can help with your 'bloody computers' problem give me a yell, have done a lot of file retrieval over the years, if it's still on there and the drive spins at all, I should be able to get your old pics for you. Cheers, |
#51 | ||
74xbkoop
Thanks Bluebear for the comments and the offer on the computer issues. Unfortunately the drive won't spin any more after it was formatted it failed a short time after. I have another drive that I'm going to change the drive Pcb over to see if I can get it to run again when I get time. Hopefully it will run again. Then I can try and recover the hidden data. Time will tell its a rainy day thing.
See ya Anthony |
#52 | ||
Shockwave
Cool, sounds like your on the right track PC wise as well.
Looking forward to more updates from you. Cheers, |
#53 | ||
74xbkoop
Hi all,
Sorry for no further details. This year has been hectic at work and now just about to take out the motor for some major upgrades before Echuca. Nothin like leaving it to the last minute. More on the thread will happen after Echuca. See ya |
