I have a 2012 Focus Trend hatch with a set of Continental factory fitted tyres, I get a fair bit of trembling through the steering wheel, it's not a lot but you can feel it on all types of road surfaces.
This week I went in and had the tyres re-balanced but I still get this slight murmur it's driving me nuts. I was wondering if any othe Focus owners have experienced this. |
Sport diesel here, and no vibration present. Tried to hit up ford yet to get to have a look at it? Hope you get it sorted soon.
#3 | |||
#4 | |||
Sorry mate.
I've got a sport diesel (mentioned in case it was a model specific problem) and I DON'T have any vibrations as you've described. was also asking if you've mentioned it to Ford as it sounds like a warranty problem, given you've already had the wheels balanced again. Still hoping you'll get it sorted soon ![]() |
#6 | |||
After a trip to Perth I found this car too under-powered with the Aircon on so I traded it in for a 2 litre Trend, I decided to keep my after market rims so I swapped the rims and tyres onto the new Trend Focus. When I got home I had the tyes re- balanced as I notice this slight murmur through the steering wheel but it didn't improve any. I have been reading that either the faulty engine mounts or the drive shafts can cause this. It's not that the steering wheel vibrates that bad but you can certainly feel something there and even coming through the accelerator pedal. ![]() Last edited by rpps; 19-04-2012 at 08:48 PM. |
#7 | |||
#8 | |||
Thailand Specials
I had the same issue with the steering wheel shaking side to side on my first LV Focus.
Then I totalled it and my new one didn't have the issue, lol. |
#10 | |||
#11 | |||
#12 | |||
FORD FOCUS Titanium Sedan with Sports Executive Pack in Midnight Sky GDI Going somewhere isn't why you drive, driving is why you go |
#13 | |||
I guess I will have to get use to it and try not to focus on it No pun intended ![]() |
#14 | |||
#15 | |||
#16 | |||
#17 | |||
#18 | ||
Thought I solved my problem found that the two back mags didn't have hub rings fitted, so I eagerly found some and put them on but damn the vibration is still there.
Next step Bob Jane and have them check the tyres with a radial runout gauge to see if any of the tyres are out of round. If not back to Ford to see if something else mechanical could be causing the vibration, like engine mounts or drive shafts. |
#19 | |||
