Hey guys,
I just snapped a clip changing my headlights, does anyone know where to find the whole headlight 2010 passenger side assembly in sydney? I don't want to pay genuine ford prices if I can avoid it. Cheers, Arnie
2010 Focus TDCI |
There's this one on eBay with free shipping Australia Wide
![]() http://www.ebay.com.au/itm/08-09-10-...-/261007398922 |
I saw that one, It looks a bit different to the one I have in my TDCI. The one in my car does not have the black outline.
Looks like I will have to either get both assemblies or pay ford prices. Cheers.
2010 Focus TDCI |
Try some local wreckers first mate they should be able to source one for you
Thailand Specials
I asked at Ford for a new set, I got quoted around $400 each I think, if you get desperate check out www.european-parts.net.
http://www.european-parts.net/catalo...roducts_id=788 I've ordered stuff from them before. |
#6 | |||
Where to next??
I'm assuming the clip you broke is one of the 3 that locate the light? From what I remember they are longish, perhaps 40mm and just the end is what goes into the body work. I almost broke the clip changing the globe myself. The instructions are stupidly vague and mention that you need to unplug the harness, something that wasn't needed....
___________________________ I've been around the world a couple of times or maybe more....... |
http://www.fordpartsuk.com/shop/ford...9660_c_553.htm
This one's a reasonable price, though not in Sydney, so it might take a few extra bucks and weeks to freight it.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
It was the tab that holds the light into the whole assembly.
2010 Focus TDCI |
Ok so I got the assembly off formaz for $150 for those interested, luckily he had a 2010 standard model there. I also called up Ford, 2 dealerships who quoted me $380.
Anyway I recommend removing the cable for the passenger side assembly, and moving it to a well lit area to slot the globe in.
2010 Focus TDCI |
#11 | |||
Where to next??
I do also remember the new globe was hard to seat correctly in the hole. I had to apply a little pressure on the steel collar of the globe (by way of a screw driver) to get it to fully contact the plastic around the hole. If you still have the broken light do you mind taking a detailed pic of the broken bit and posting here? Would be good to know where the weak point is so some of us don't do the same thing. Cheers, Jason
#12 | |||
No I knew what I needed to do, it was as you said I gave the steel(plastic) collar too much gentle persuasion and it snapped off. I will get a shot of the broken collar. Will take a photo a bit later.
2010 Focus TDCI |
