05-06-2011, 03:52 PM | #1 | ||
hey guys apart from getting a brand new one from the uk for like 500 pounds where cold i get one here in aus ??
10-06-2011, 07:09 AM | #2 | ||
Hi mate i can get you a loom;-)
11-06-2011, 01:36 AM | #3 | ||
hi there how much am i looking at for the loom cheers ??
11-06-2011, 07:05 PM | #4 | ||
RS2000 COSWORTH
Are you going to use an aftermarket ECU such as Autronic or MoTeC? I highly recommend this as even the standard engine with good quality ancillaries will make 385hp at the wheels...
We made a new harness and it is easy with a little thought... The standard ECU is no good for tuning, yes there are chips and all that, but they restrict what you can achieve....... in the end it is better to do the job properly and once, you will have a much larger grin and with reliability you will be over the moon... What car is this in and what model engine do you have; Turbo used, injectors, ignition?....For interest sake... CheeRS, Mark. |
14-06-2011, 03:53 PM | #5 | ||
Its a 2wd engine as far as i know its just a standard engine no work done i need to get a turbo for it still undecided i was thinking of just doing what everyone else dose and run the dark green injectors the 803 i think they are ? and yeh not to sure on ignition i used to run one of them crane fireball inginiton set ups but it burnt out i had heaps of issues with it so yeh any info would be a great help im looking to try get about 350-400 hp atw .... oh and its going into a mk2 escort 2 door
