Old 01-06-2011, 07:55 PM   #1
R0BD0G
R0BD0G's Avatar
Default Mk2 Cortina Door Lock Issue????
yeah just for a change im messing around with cortinas. anyway the particular one im working on seems to have never had a passenger side door lock and the drivers side only locks from the outside with the key. the passenger side inner handle will go down to the point where it feels as though it has locked but hasnt, to put it loosely in lingo. when you pull the handle up the door opens, when you push the handle down it clicks but doesnt do anything but click? ive had the door card off and looked inside the door and i just cant see how it ever locked...,..... so anyone that can help...
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 07:42 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Default Re: Mk2 Cortina Door Lock Issue????
Rob
quite a few early fords only had a key on the drivers side & had to lock the passenger door from the inside and drivers door with Key
so really nothing is wrong, they were made like that
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 06:19 PM   #3
R0BD0G
R0BD0G's Avatar
thats a very useful bit of info there puzz... thanks. so it should lock from the inside off the door handle?
Old 02-06-2011, 11:32 PM   #4
wombat2509
wombat2509's Avatar
The up side of it is you can't lock your keys in the car
wombat2509 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2011, 08:35 AM   #5
66GT
You can lock the keys in if you get tired of always having to use the key to lock the door after you exit if you cheat a relock the door just after you unlock and open the door to get into the car. Luck I did this stupid act at home and could access the spare key easily.
66GT is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2011, 03:00 PM   #6
crispymk2
crispymk2's Avatar
Yep, there should be two positions for the inside door handle on the passenger side. The drivers handle locks from the outside but from memory you cant lock the drivers side door from the inside.
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
crispymk2 is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2011, 07:16 PM   #7
R0BD0G
R0BD0G's Avatar
on the money there crispy..
