24-03-2011, 02:35 AM | #1 | ||
WOGBOY69
Hi all
as you all know i have been rebuilding my ford capri. v6 . at the end of the day i have now got to the stage that nearly complete 99.9% but now i have a new supprise its make bearing noises from the rear end ..the diff..when the diff was out i changed the wheel bearings and put new oil in it ..now it makes alot of winning noise so ill have to pull the diff appart and change bearing and shims and gaskets to do it right but the problem is were to i get the full kit from here in queeensland or brisbane ,,anywere local .. i just emailed bearingkits in the uk .and now they will not deliver to australia anymore ,great help they are now so if anyone knows please tell me cheers gerry |
24-03-2011, 04:08 PM | #2 | ||
Hi wogboy, my diff seems to have similar problems to yours.
Research Ive done so far ; Burton power has all the parts needed. There is a diff specialist in Kedron www.difflap.com.au ph 3359 4701 An excellant transmission specialist in caloundra called top cog. |
