I.B.S is a pain in d'***
I am not too familiar with the 12 slotter wheel and their centre caps.
Do they leaver off (with a flat screwdriver) or spin off? I am asking cause i leavered off one and it wont stay on now. Do you screw them in? I sound like and idiot right?
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then ![]() |
owning V8=having no $$$
Some leaver off and some have a screw off thread....If you can see a thread then it's a screw off. Most 12 slotters just pop on with a slight tap..If it keeps falling off then maybe your cap is stuffed.
Weekends - 1965 XP 302 sedan... ![]() Weekdays - 1980 323 Mazdabator complete with cheese cutters & FF sticker :dr_Evil: The Reality: 13.1 @ 106mph.... The Goal: somehow get into the 12s!!! :sm_headba www.qldsuperkart.org |
From what I've seen, the "orginal" style ones are an "interference" fit .. metal bracket held by the wheelnuts that the cap fits into. The newer (cheaper) ones have a plastic thingy with a thread on it that the cap screws onto. Should be pretty obvious which one you have. I'd say you have an interference fit set but the tabs on the bracket are a bit dicky? Maybe try fiting the cap in and rotating it?
There is also a small hole in the cap. I assume thats to let out water? or is that so you can stick something into it and leaver out the flange to make it fit tighter?
AFAIK the bracket is for the 8inch and over deep dish rims and the shallower dish 7inch and under just tap in and lever out.
#6 | |||
The rear on my car are the wide (deep dish) the fronts are the smalls. I have tryed to tap in the caps on the front and they wont stay on! What should i do. Sorry, but can you explain how the caps on the rear work?
#7 | |||
Giddy up.
#8 | |||
Giddy up.
#9 | |||
i haven't noticed. i'll check and get back to you.
The bracket i am on about must be aftermarket then , because that is what holds the caps on the 12 slotters on the back of my XC ute.
It is a round bracket that fits over your wheel studs and is held on by your wheel nuts
