Old 30-06-2010, 01:31 AM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Capri V6 Vaccum Advance
Hi All
Just Like To Know Were Can I Get A New Vaccum Advance For My Dizzy ..
I Have A 1972 Gt Capri V6 Manual ..and Iam Looking Every Were And Cant Find Notthing ..
Need Help
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2010, 10:10 PM   #2
Blown66
If its not blown it sucks
Blown66's Avatar
Try the Capri Clinic in Perth.
Blown66 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2010, 07:18 AM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
what about trying scorcher or a replacemnet dizzy
unless you would like to stay original it may end up easier to replace the whole dizzy with a newer item
or try fleebay UK, dollar is pretty good still at the moment
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2010, 12:02 AM   #4
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
tryed and tryed all the above ...not happing
Old 02-07-2010, 10:26 AM   #5
Engine Guy
What's actually up with the old vac? is the diaphrarm split?
have you tested it? put a small piece of pipe on it and...suck - if the 'arm' that goes into the distributor moves then it's fine.
If you don't have one, then you could probably use one from a Pinto motor
(pretty sure the spring rate/vacuum are very similar), but it's been a while since I worked on these)
Engine Guy
Engine Guy is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2010, 08:26 PM   #6
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
thanks engine guy .but i have sucked and yerrr the diafreme is shoot it does not work at all ...
so do you think the pinto one works for the 2.0 litles mod
cheers
gerry
Old 02-07-2010, 08:37 PM   #7
tufLTD
tufLTD
tufLTD's Avatar
Try Recarb at Kawana, Sunny Coast. They recondition vacuum advances.
My favourite quote:
"Some people compare David Gilmour to God. He's great, talented & inspiring, but he sure as hell can't play the guitar like David".
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2010, 02:00 AM   #8
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
ill try them out next week .since iam there for a couple of days next week for work see what they have to say
cheers
