read title.
Performance moderator
![]() Join Date: Feb 2005
4 ever...
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
#3 | |||
avenge me
FULL OF Autotech GOODNESS! |
#4 | |||
Keep the bottle closed so no moisture can enter it and it will last years. |
Like a good red...
Giddy up.
That's good to hear as I have used some old stuff before, when I say old, I bought a 20ltr drum as it was cheaper and did all my own oil changes, and as I don't do many klm's a yr, it was a fair while till I used up the 20 ltr drum, I keep't it clean and in a cool enviroment.
#7 | |||
zdcol71
windsor user
if there were a shelf life, it would be on the bottle
I am Groot
![]() Join Date: Dec 2007
Just to mix things up a bit....
Scroll to bottom of the page... http://www.carbibles.com/engineoil_bible.html Engine Oil Shelf Life. I couldn't decide whether to put this in the FAQ or the main page, so it's in both, because I get asked this question a lot. Typically, the question is along the lines of "GenericAutoSuperStore are having a sale on WickedlySlippy Brand synthetic oil. If I buy it now, how long can I keep if before I use it?" In general, liquid lubricants (ie. oils, not greases) will remain intact for a number of years. The main factor affecting the life of the oil is the storage condition for the products. Exposure to extreme temperature changes, and moisture will reduce the shelf life of the lubricants. ie. don't leave in the sun with the lid off. Best to keep them sealed and unopened. Technically, engine oils have shelf lives of four to five years. However, as years pass, unused engine oils can become obsolete and fail to meet the technical requirements of current engines. The specs get updated regularly based on new scientific testing procedures and engine requirements. But this is only really a concern if you've bought a brand new car but have engine oil you bought for the previous car. An oil that is a number of years old might not be formulated to meet the requirements set for your newer engine. If your unopened containers of engine oil are more than three years old, read the labels to make sure they meet the latest industry standards. If they do meet the current standards, you might want to take the extra precaution of obtaining oil analysis before using them. An oil analysis will check for key properties of the oil and ensure that it still meets the original manufacturing specs. Of course the cost of getting an analysis done on old oil is probably going to outweigh going and buying fresh stuff. So it's a double-edged sword. As a general rule, the simpler the oil formulation, the longer the shelf life. The following is a guideline under protected conditions: Product Shelf Life Base Oils, Process Oils 3 years Hydraulic Oils, Compressor Oils, General Purpose Lubricating Oils 2 years Engine Oils and Transmission Oils 3 years Industrial and Automotive Gear Oils 2 years Metal Working and Cutting Oils 1 year The following are signs of storage instability in a lubricant: •Settling out of the additives as a gel or sticky liquid •Floc or haze •Precipitates/solid material •Colour change or haziness Water contamination in a lubricant can be detected by a "milky" appearance of the product.
.. ![]() ![]() ![]() ![]() "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
#10 | |||
avenge me
would mineral oil and synthetic also have different shelf lives? to the OP, i get my oil in bulk from my mate who works for FUCHS and he gets me 4x5l bottles instead of a single 20l drum purely so "it doesnt go off". theyre his words not mine
We have drums of oil sitting around for ages at work, I usually give them a shake and then decant onto a clean rag, if it looks clean, good to go!
Only mineral though, Hydraulic and synthetic get a much closer inspection.
'03 BA Futura, 18' -235/40, Kingsprings superlows, Monroe GT Sport, 2.5" Cat and exhaust, K & N, Typhoon CAI, RDA Slotted & Extreme pads. 302 Cleveland being rebuilt, Ebay said 351 liars!!!!! Home found! '01 AU II. Bring on the smoke ![]() |
#12 | |||
If your THAT concerned mate change your oil every 1000k's. Oil 1000k's old will be worse than oil stored properly for 3 years. |
#13 | |||
avenge me
FFS way to make a good thread into a bitchfest
#14 | |||
Every time your engine cools you get condensation on the inside of your crankcase. By heating and placing the oil under pressure you are shearing the friction modifiers within the oil, effectively changing the oils weighting over time. This would not happen to sealed oil. |
#15 | |||
avenge me
i usually change my oil between 3000-5000km because it doesnt get driven much so i probably wont have issues with this i have 2 unopened bottled of syn and 1 open (4 litres left) will these both "go off" in the same timeframe?
#16 | ||
stop thinking so much.. your head will hurt....
#17 | ||
71Mach1
haudraulic lifters not so important
solids a bit more important also crusing not so important racing/redlining more important all oils will lubricate only the better ones will prevent serious damage if metal contacts metal under severe circumstances... Have we had the ZDDP discussion anywhere...?
roses are #FF0000 violets are #0000FF all my base are belong to you |
#18 | ||
Walking with God
I keep some older oil around the place (say 5 or more years) in sealed containers, in case I want to flush the diff or gearbox when I do a fluid change.
As for the cars though, I wouldn't really keep oil for longer than a few years. I do buy a number of containers when it's on special however! LOL! GK
#19 | ||
This one I decided to bounce off the Chemists (even though I have my own opinion)
The text book says around 2 years (you know how I feel about text book worriers) Guide lines as follows, you need to consider ...... As long as the OLD spec still protects your machine. As long as the container was resealed after opening. (if left open to the air can oxidise) Stored under cover (not in rain or sunlight) under 40C The maximum I would (and the Chemist would) keep oil and still use ....... 10 years But the book says 2 years (they're hoping you'll buy more!) Cheers Steve
MainLube - Extreme Lubricants For Overdriven Machinery Mainlube 175 Synthetic Race Oil SAE 10w60 (engine) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff) www.Mainlube.com.au |
#20 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#21 | |||
avenge me
#22 | ||
Rob
while the oil i use is readily available, i see no reason to stock pile it. buying in bulk is sometimes cheaper but it can depend where you buy it from. i use shell helix ultra, which is upwards of $60 at most auto stores and sometimes over $70 for 5L. it is also available at BIG W for $40 - $50!! they obviously have much better buying power than your average auto store.
#23 | ||
Peter Car
Depends how quickly you put it in the fridge after opening.
#24 | ||
71Mach1
I've got 4 tins of full gloss and semi gloss por15 in our main fridge
been there for 2 years? keeps longer.
#25 | |||
You dig, we stick!
