Old 28-12-2006, 01:01 PM   #1
white lightning
white lightning's Avatar
Thumbs up MK 1 Escort 6 Dial Tacho wiring
I need some advice please!!! :togo:
Where does the tacho wire/connect too? :
I am converting my standard 2 dial dash to a 6 dial one. Everything but the tacho works fine.
I just need to know where the little white wire at the rear connects too please??
Any diagrams?
many thanks
Shane
white lightning is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 01:10 PM   #2
rynostation
rynostation's Avatar
in my experience, tachos usually run a four wire system,
Red to accessory, Black to ground, Green to negative side of coil, and White to your illumination (i'd wire this one up with the instrument globes that fire up when the headlights are on)
rynostation is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 04:37 PM   #3
bigmatt4
it goes to the coil negative wont be a wire in the standard loom so u will have to run one
bigmatt4 is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 06:33 PM   #4
1600-escort-72
hey dude, when you converted your 2-dial dash to a 6-dial. did you make up a template or just hack into it? im trying to do the same thing to my mk1 escort, convert from a 2-dial to 6-dial
cheers
-Rogs-
1600-escort-72 is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 07:19 PM   #5
R0BD0G
R0BD0G's Avatar
i just did the tacho wiring for my mk1 although not in a 6 dial.. and do it just as rynostation said.
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2009, 08:42 PM   #6
white lightning
I just held the 6 dial against the metal, drew around it in texta and started cutting.
Filed to smooth off, job done.
Re connection of the Tacho....the little white wire on the tacho plugs straight into the loom at the back of the dash There is a blacck wire that has a bullet type connector....the white wire plugs into that : you can't get it wrong.....
