Old 16-06-2005, 08:51 PM   #1
Stav
Smile
Stav's Avatar
Default 1/4 mile question??
What is the most important time for a racer in a 1/4 mile race?
Is the 0-100 speed indicative of a great 1/4 mile time or is it the power between 100 +which really makes a difference pulling the car to a great time?
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 16-06-2005, 08:53 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
the 60ft and mph is the key
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:00 PM   #3
Stav
Smile
Stav's Avatar
So the quicker 60ft (18.28 metres) plays a big part? So would it be the best starting point to concentrate on 60 ft times on a six? If 60 ft times are great does this normally mean a great 0-100 and better 1/4 mile?
Old 16-06-2005, 09:04 PM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
normally, if you can get the car off to a good launch the ET will be good. Saying that though a slow 60ft time but a healthy mph shows the car has good power and in an ideal world could run a better ET.
Old 16-06-2005, 09:06 PM   #5
MO
MO's Avatar
And don't wheelspin when launching,maintain traction at all times.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:11 PM   #6
Stav
Smile
Stav's Avatar
So a car like mine which now puts out a respectable 137rwkws can benefit from all of the torque possible in the low to mid ranges??Right?
Old 16-06-2005, 09:15 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
it depends.
a 6 with a stock cam and stock stall will have a better 60ft time then a car with wilder cam and stock stall, simply due to the design of the cam and its peak power ranges.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 16-06-2005, 09:21 PM   #8
mcflux
mcflux's Avatar
and having an awesome 0-60ft time would mean nothing if the car is geared so shortly that it's bouncing off the limiter 3/4 down the track (although in your case this won't happen!)
There are so many factors to consider...
Old 16-06-2005, 09:23 PM   #9
Stav
Smile
Stav's Avatar
Originally Posted by EFFalcon
it depends.
I have finally dialled the cam in and it has noticeably taken away some low end.I have recorded the wrong setting.At this setting my car felt like a line munching machine despite the less than expected peak power.The gtech will tell me how good it is at the moment. Ilike hearing your experiences because it gives me good ideas. It is true that the more low down torque and engine produces that the stall speed goes higher than a lumpy butt cammed engine.
Old 16-06-2005, 09:26 PM   #10
Stav
Smile
Stav's Avatar
Yes I agree with that .What I am intersted in is the engine power characteristics which make the car respectable.Does it sound to you that the line munching feeling I had is a better state of tune than the gluggier low down state of tune?
Old 16-06-2005, 09:31 PM   #11
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Remember MPH is your HP, ET is only how you lay down the HP. MPH is everything.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 09:34 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
i'd still prefer a 12 second ET
then a 13 second ET while wheel spinning the first 1/8th track :P
as good as MPH is... its only gunna get u killed ;)
Old 16-06-2005, 09:39 PM   #13
Stav
Smile
Stav's Avatar
I am limited in power.
True.My little bro has a bmw that put out 135 rwkws on the same dyno.Those things do 14 second quarter miles..its a 330ci coupe. Becuase I am limited in power I wonder if should stop worrying about getting more power or simply spend a day at a private track fiddling with cam settings,intakes and checking times. Adjust ,then time and see the differences.Adjust see time and then move to a better medium.?? What do you think?
Old 16-06-2005, 09:43 PM   #14
mcflux
mcflux's Avatar
I tried to sound as sage as possible but you called my bluff! BAH! :monkes:
Well with a cammed six its power band will tend to be shifted higher up in the rev range. Ideally I suppose you should decide on your gearing, then see what gears/revs will be most common down the 1/4, and then cam it/tune it to match. But that's being short-sighted and focusing on the 1/4 only.
I don't want a 1/4 mile king, otherwise I would've bought a blown-350-equipped torana with some crazy gearing like a powerglide & 4.11 or shorter diff gears :P (or a rotary! or a turbo bike!) So in reality, my heavy Ford will score some 3.7 gears for a balance between street and acceleration ;) At the moment I can pull 108kph in 1st gear : so she's hardly quick from takeoff!
-Dave-
Old 16-06-2005, 09:45 PM   #15
mcflux
mcflux's Avatar
.its a 330ci coupe.
(off topic) mmmm who else thought of a BA BOSS powered XA-C coupe when you read this? :
Old 16-06-2005, 09:47 PM   #16
Stav
Smile
Stav's Avatar
-Dave-
Being a daily driver and alround car + auto I will be looking for that fat torque curve.I think this will show up in better times.
Old 16-06-2005, 10:37 PM   #17
stockstandard
I dont think that any amount of fine tuning cam timing is going to get much better times unless the cam is way out (which yours shouldnt be now). I am no 1/4 mile expert, but when it comes to auto's I think the key is just to get of the line as hard as possible without smoking it up (a little wheelspin isnt that bad) and then keep the hammer down. Gear ratios and stall convertors will help you do this!
My 1/4 mile times are an example of what you dont really want - cossed the line at 95mph showing I have got good power for a NA I6, but with a relatively slow ET of 14.8 showing that I couldn't get that power down well (3.08 open wheeler diff). If I matched the gear ratios with the engines power band I would have a much better ET.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 10:40 PM   #18
Stav
Smile
Stav's Avatar
Lets face it...an i6 can only make so much power even with a full rebuild. 200 rwkws on a normally aspirated six doesnt happen...So I think this the way to go test then time it!!!The dynos are a great tool but dont necessarily give time improvements on mods.
Old 16-06-2005, 10:44 PM   #19
Stav
Smile
Stav's Avatar
I think you are right.Getting the max power to the ground without wheelspin is the ticket to a quicker car.Or a manual conversion for the AU.I was shocked to find that from manual to auto the difference can be 15rwkws !!So for the price of the conversion I would be getting better power to the ground and more control on takeoff.
Old 16-06-2005, 10:46 PM   #20
EFFalcon
Last warning
EFFalcon's Avatar
the power difference between a manual and a auto is not 15rwkw.
Old 16-06-2005, 10:49 PM   #21
stockstandard
I agree. manual vs auto isnt 15rwkw (that would put a stock manual ef/el xr6 at around 125rwkw). Its more like 5rwkw peak power and I hear that somehow autos produce more torque down low for some reason (torque multiplication??). Manuals in general might have 15 more kw due to the fact that they are more likely to be modded (being a more sporty car).
Old 16-06-2005, 10:49 PM   #22
Stav
Smile
Stav's Avatar
how much do you think it is?Have you seen it?
Old 16-06-2005, 10:51 PM   #23
Stav
Smile
Stav's Avatar
ok ..so just say I go the higher stall converter should I see an improvement or uncontrollable wheelspin?
Old 16-06-2005, 10:54 PM   #24
EFFalcon
Last warning
EFFalcon's Avatar
well that depends completely on ur car.
my car has no traction issues at the moment.
but it it did, and i added a stall, then i would have more problems..
Old 16-06-2005, 10:57 PM   #25
Stav
Smile
Stav's Avatar
My AU is a 1720 kg car. With the wrong cam timing it would smoke the tyres uncontrollably around corners like it was possessed.I think I liked it better that way ..it felt a crapload quicker despite its slightly lower power figure.
Old 16-06-2005, 10:59 PM   #26
Stav
Smile
Stav's Avatar
I have talked to some other au owners here in Sydney with much more power than me and from the sounds of it I will blow their doors off 0-100 kmph.Big power on dyno and a slug on the street.I suppose with a six cylinder we are somewhat limited to make the best of what we have..which isnt too bad when put to the ground properly.
Old 16-06-2005, 11:09 PM   #27
Walkinshaw
Two > One
Walkinshaw's Avatar
DELETE ME
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 11:09 PM   #28
stockstandard
the only way to know is to take your car to the 1/4 and try them
I would say give your car a run as is. Your timeslip will let you know exactly where your actual strengths and weaknesses are. Then youll know what you should be putting your time and money towards improving.
If nothing else it is a hell of a lot of fun!
Old 16-06-2005, 11:10 PM   #29
Walkinshaw
Two > One
Walkinshaw's Avatar
Get a decent suspension setup and tyres to eleviate your traction problems.
A very mild I6 needs all the low down power is can get to get a decent 1/4mile time. Trading 40nm down low for 10kw up top wont work for auto I6's.
Old 16-06-2005, 11:25 PM   #30
Stav
Smile
Stav's Avatar
I agree.
If nothing else it is a hell of a lot of fun!.
Yep I had gotten into a bit of a psychotic rut with power levels..now I see that Its better to smoke it a bit off the line with a smile then smile once a year on dyno day!!
