Old 10-08-2006, 08:01 PM   #1
Stav
Smile
Stav's Avatar
Default Effects of humidity?
What are the effects of humidity on a 1/4 mile run?
Old 10-08-2006, 08:19 PM   #2
CAMS290
trying to get a leg over
CAMS290's Avatar
Sweaty crotch.lol
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2006, 08:22 PM   #3
gurujosh
i dont think there is alot.i did my quickest run at 98% humidity
gurujosh is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 10:11 AM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
Free water injection
Old 11-08-2006, 10:37 AM   #5
brenx
brenx's Avatar
Humidity if higher in my experience makes for faster 1/4 times ;)
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 11:04 AM   #6
Hardtopxb
Once PHASED.
Townsville. Humidity alwasy high up here.I run drags and track,and find if I venture down south with the same set up I always run better times..(ie, less humidity)IMO.
2006 BF XR8 Bionic.
Hardtopxb is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 05:34 PM   #7
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Stav realy hot days with very high humidity like the AFF day (36c 100% rh) in January most people were about .4 off there best which had a RA of about 3500ft and for every 1000ft drop in RA you should gain roughly about .15
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 05:37 PM   #8
Quadcams
Quadcams's Avatar
Stav play around with this density altitude calculator and you will see the differences humitiy, air temp and ABS will affect air quality.density altitude calculator
Rembering WSID is at 230ft and take into account good air is below 1000 RA (relative altitude)
Old 12-08-2006, 07:37 PM   #9
marcuss
higher humidity = less horsepower. basically, water displaces oxygen
marcuss is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 08:31 PM   #10
brenx
brenx's Avatar
My timeslips @ Heathcote show otherwise. Humidity increases and the times start falling quite rapidly. In low humidity I run slower.
Old 12-08-2006, 09:38 PM   #11
Quadcams
Quadcams's Avatar
Brenx did you look at the difference in the RA on those occasions as I have noticed in cooler temps the humidity doesnt play a big factor but in high temps high humidity (muggy conditions) will kill power big time.
Old 12-08-2006, 09:52 PM   #12
brenx
brenx's Avatar
Whats RA?
I've only ran the XB once during the day. I'd have to check my track data but I'm sure my fastest time for the day was set on a high 20's deg day. Our meets are usually night meets.
Old 12-08-2006, 10:19 PM   #13
Quadcams
Quadcams's Avatar
Whats RA?
RA = relative altitude is where the air quality is measured in a scalce (in feet) of how good the air is, its worked out by taking in account the air temp, humidity, barometric pressure and the height at which the reading the was taken (for example WSID is at 230ft above sea level), air quality only starts to get good when the RA drop below 1000ft as the closer to sea level the denser the air but will vary with different air temps,humidity and barometric pressures for example WSID might be at 230ft above sea level but the air quality might be only equivilant to say 1250ft above sea level when the RA takes into account the varing conditions. If you find out what the height calder or Heathcote is above sea level you can use the RA calculator I put up a few posts earlier to work out how good the air is you raced in, some tracks will have the RA on your time slip like willowbank does but WSID only has air temp, humidity and barometric pressure but if you have those 3 you can work out the RA with the calculator. Also I have noticed for every 1000ft drop in RA you should gain about .15 in your ET. RA is the only thing you need to check to see how good the air is where 0ft is awsome air to say 3500ft which is total crap air.
Old 12-08-2006, 10:25 PM   #14
brenx
brenx's Avatar
Heathcote doesn't have the RA data on their slips. They only have barometer, temp, humidity, wind speed and wind direction.
Old 12-08-2006, 11:10 PM   #15
Quadcams
Quadcams's Avatar
Yeh brenx I have some heathcote slips in front of me, they only read the air pressure in millibars (mb) where WSID is in ABS (absolute pressure in hg). I will find out how to convert mb into ABS then you will be able to use the calculator.
Old 13-08-2006, 11:15 AM   #16
Quadcams
Quadcams's Avatar
Brenx heres a weather conversion calculator which will convert millibars to hg (mercury), then all you need to know is the altitude of heathcote from sea level then you will be able to use the densisty altitude calculator to work out the RA.weather conversion calculator
Old 13-08-2006, 12:33 PM   #17
northey
The fact is, as stated above, dense air contains more oxygen. High humidity is not conducive to making good horsepower. Engines make more power in cold air.
If you need proof on the track have a look at how many records are set at the Winternationals at Willowbank. It's always cold, the air is usually very dense. I believe last Winters though the air was 1000 ft above sea level which is not very good for that track.
If a car goes better in humid conditions than it does in cold air it may need a set up change. Remember that as the sun goes down and the air cools the track can get a mild to heavy dew on it as well. Some cars won't adapt well to the change in grip levels.
It doesn't matter what opinions are here. A correctly tuned engine makes more power in cold air. Whether that can be applied to the track is a different story.
northey is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 12:44 PM   #18
Hardtopxb
Once PHASED.
Absolutely correct..From experience..
2006 BF XR8 Bionic.
Old 13-08-2006, 03:17 PM   #19
xdclevo
The Fun Mobile
xdclevo's Avatar
Thats why turbos boys like winter, as the air is cooler and dryer. If you went faster in humid weather, maybe your jetting is too lean. I find in winter with the "good air", i have to richen the jetting a bit to compensate for the denser air supplied, and increases effeciancy. When humid, the extra moisture in the air makes for less oxygen to burn, hence not needing as much fuel, which drops power off some.
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 03:19 PM   #20
brenx
brenx's Avatar
12.7AFR and 1320deg F exhaust gas temp is spot on.
Check the air temp and humidity -> http://www.users.on.net/~brenx/images/Timeslip_20_05_06.jpg
Prior pbs 393 - 11.14@121.92, Air temp 25.9, humidity 31%, barameter 987
351 - 11.85@115.83 Airtemp 9.8, humidity 92%, barometer 994
Old 13-08-2006, 04:17 PM   #21
xdclevo
The Fun Mobile
xdclevo's Avatar
How do you know the tune was spot on with the better air? And when you had your motor dynoed is a different story than when you race a year on, with different extractors etc.
But if you think humidity is better for power, no one is probably going to convince you different, so good luck!
408 cube Cleveland
10.7 @ 125 mph
2V powahhhhh
Old 13-08-2006, 04:21 PM   #22
brenx
brenx's Avatar
I've done plenty of R&D with my engine/car. I know where it's at.
I also stated before the last AFF drag meet the humidity would increase and the pb's would roll on. Humidity increased and the barage of pb's went through the roof. It's not just one racer. Plenty went faster with the high humidity.
Old 13-08-2006, 04:41 PM   #23
Hardtopxb
Once PHASED.
No worries Brenx, your car just goes against the laws of thermodynamics.Good on you mate..
2006 BF XR8 Bionic.
Old 13-08-2006, 04:52 PM   #24
brenx
brenx's Avatar
Sometimes things just work. Things look like they shouldn't work just do ;)
Old 13-08-2006, 05:58 PM   #25
Quadcams
Quadcams's Avatar
The 11.14 run the RA was 2561ft (crap air)
The 11.85 run the air was 467ft (awsome air worth about .3 off ET )
Mate there was something going on with the 11.85 run also what was your 60ft for both runs as the air on that run was excellent.
Out of the 3 the biggest factor is air temp to improving air density/quality dont just look at humidity, I have raced a WSID in 100% rh but the air was 15c and with a RA of 650ft quiet good air but because the humidity was so high the track was getting slipery from dew.
Old 13-08-2006, 06:02 PM   #26
brenx
brenx's Avatar
Out of the 3 the biggest factor is air temp to improving air density/quality.
Different engines ;)
Old 13-08-2006, 06:07 PM   #27
Quadcams
Quadcams's Avatar
Well you cant even compare the 2 times then ;)
Old 13-08-2006, 09:01 PM   #28
troppo
Mr old phart
troppo's Avatar
Guys, you need to remember that humidity is a relative thing. 100% humidity is the maximum amount of moisture the air can absorb, but how much water it takes to reach that maximum varies significantly depending on temperature.
In a nutshell, humidity has very little effect at low temperatures. As temperatures increase, the effects of humidity increase exponentially.
Imagine a room full of air at 0 deg. The amount of moisture in the air would only be a few drops. It's because :a) the air at that temperature can absorb bugger all moisture and b) any moisture at that temperature is likely to be liquid and difficult to be absorbed.
If you increase the temp and add steam, you would maintain 100% humidity. At 5 degrees you would have added a cupful of water. At 10 degrees you'd need a litre. 20 degrees would need a bucket full of steam, 30 a large drum, a 44 gallon drum at 40 and so on.
De-humidifiers work in reverse. They take hot, wet air and cool it down, which forces out the moisture as condensate. You end up with cold air thats still 100% humidity and a big puddle. Remove the puddle and allow the air to warm up again and you have warm, dry air. Cold air at 100% humidity can still be drier than hot air at 50%.
RA is way a way of relating changing air pressure to a fixed scale between sea level and the the outer atmosphere.
Imagine standing inside a huge column at sea level. The air pressure you feel is the result of gravity acting on the mass of air inside the column above you. The higher you go in the column, the less mass there is and therefore less pressure at that point. If you know your altitude, you can theoretically calculate the air pressure and vise versa. This is how plane altimeters work. If you took one to the dragstrip on day when there was a high pressure system in the area, it would read a certain altitude. Same place on a day with low pressure system in the area would make it read a lot higher altitude.
Ideal conditions are low temperatures, low humidity, low altitude and high air pressure.
An object at rest cannot be stopped!!
BA GT-P Blueprint
troppo is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2006, 09:09 PM   #29
brenx
brenx's Avatar
I'm not comparing the 11.85 time to the low 11's The car was running 12.1/12.2's all night. As soon as the humidity went up the times dropped. On average I do 5-10 pass's per meet.
I've done quite a lot of racing at Heathcote raceway. I know at Heathcote as soon as the humidity rose the times fall.
Old 13-08-2006, 09:14 PM   #30
troppo
Mr old phart
troppo's Avatar
Check your slips. I have a hunch the increase in humidity coincides with a decrease in temperatures. Cooling air means relative percentage will go up, although actual volume of moisture doesn't change much at all, unless it cools enough too reach 100%, then moisture starts getting forced out of the air as dew or condensate.
BA GT-P Blueprint
