Old 22-05-2013, 09:54 PM   #1
mick canning
Default M2 ford escort
Hi I am building a ford Mexcio
I have a 1600 she'll Whitch I am installing all 2lt running gear into .
I am having trouble getting the engine to fit ,
Is there a difference in a 1600 cradle and a 2lt cradle ,
Is there different shapes of sumps
mick canning is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2013, 10:02 PM   #2
79FordEsky
79FordEsky's Avatar
Default Re: M2 ford escort
jump onto this forum http://www.classic-ford.org/cfp/ this has all the small ford guys on it sorry mods for linking another forum
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2013, 10:03 PM   #3
ebxr8240
Performance moderator
ebxr8240's Avatar
Sumps need modifying or swap with Escort sump..Depending if its from rear or front sump..
The radiator bracket needs trimming and bolted directly to front panel moving it forward and its easier to change outlet direction of thermostat housing for radiator hose..
TMK the Mexico was a 1600 ?? Love the flares etc on them..
Daily driver GTE FG..
Old 22-05-2013, 11:44 PM   #4
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
the sumps are different. I assume by cradle you are talking about the crossmember? they are different, I assume the engine mounts are different and the exhaust travels out a different side of the car. the front struts are also different.
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 02:30 PM   #5
mick canning
Does anyone know we're I would get a 2lt escort sump to fit a pinto
Old 30-05-2013, 03:28 PM   #6
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Yep, here
http://www.trademe.co.nz/motors/car-...-597751350.htm
But it would be cheaper to get your sump modifyed, and to suit your current crossmember.
And the Mexico's were 1600's sounds like you are building a RS2000 replica
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 04:28 PM   #7
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
And I think you have to modify the oil pick up, cant remember 100%, it was like 30 years ago when I did one
Old 30-05-2013, 05:42 PM   #8
Fev
Fev's Avatar
Call Brian. He's got everything (used) you'll ever need.
Classic Small Ford Supplies
Rear11/ Lincoln St Minto NSW 2566
(02) 9603 5333
Or if you want New parts only and or performance bits Smcka will have it or can find it.
http://classicescortparts.com.au/
Both are diehard Small Ford fans. Both great guys and should look after you with anything you need.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 09:42 PM   #9
mick canning
Thanks for that lads
Old 31-05-2013, 05:23 PM   #10
JimStone
Crossmember physically same dimensions for 1600 Kent & 2lt Pinto, 2lt had a stronger baseplate though. Mexico was a 1.6lt Pinto.
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2013, 06:16 PM   #11
Sprint
Sprint's Avatar
Sounds like you may have a Cortina sump? very simular but much different in the right places.
the proper 2lt escort sump is actually a rare item now. Seen a few 2lt Cortina sumps bashed in around the cross member to fit lol.
No sure ,may have a sump somewhere.
Sprint is offline   Reply With Quote Multi-Quote with this Post
