09-09-2005, 11:26 AM | #1 | |||
Hey Guys
Just had someone posting an interesting rumour on our website. Don't know if it's true or not but I thought I'd share it with you guys anyway. Quote:
Can anybody confirm/deny? Cheers
Rep Power: 0 |
09-09-2005, 11:32 AM | #2 | ||
LPG > You
Sounds a bit BS if you ask me...
LPG Lovers Association President & Member #1. : |
09-09-2005, 11:32 AM | #3 | ||
A little too optimistic I would have thought - you'd be talking about a degree of engineering that BMW puts in to the M engines, this car wouldn't be able to sell for less than $90k.
Plus the weight of the awd system would most likely push the car over the 2tonne mark, and then there would probably be exhaust issues in designing it around the drivetrain. Remember Mitsubishi and the coupe 4 have both been limited in kw produced from the exhaust design around the AWD drivetrains. |
09-09-2005, 11:42 AM | #4 | ||
An Old Boss™©
I'd say it's right up there with Santa Claus, the Tooth Fairy, the Yeti, and the new Cityrail timetable.
Where did I go? What was I doing there?™© |
09-09-2005, 11:45 AM | #5 | ||
LPG > You
Who knows.. they might release a 400kW car.. with an engine, chassis and drivetrain made entirely of lead to increase kerb weight to 2650kg.. ensuring they are slower and handle worse then the competition... :
(before anyone gets all defensive, joke! lol)
09-09-2005, 11:48 AM | #6 | ||
well i can't confirm the actual power numbers, but one of my good mates (engineer) has seen the next gen config and power targets, all he could tell me was that his jaw hit the floor.
09-09-2005, 11:50 AM | #7 | |||
No longer driving a Ford.
I smell bullsh!te. Somehow I doubt it very much.
09-09-2005, 11:51 AM | #8 | ||
Virtuous Bogan (TM)
hmm I smell some.................
09-09-2005, 11:57 AM | #9 | ||
F6 and AU Fairmont
And the new Hemi engines don't have anything new or exciting with the fuel injection on them.
The only 'different' thing is the electronically controlled soleniod activated hydraulic lifters, that deactivate the 2 inner cylinders on each bank to conserve fuel. A 254kW 5.7L engine is hadrly a huge advance over the boss motor. And the R/T's get more power by increasing displacement to 6.2L. Sound like CR@P to me... |
09-09-2005, 11:57 AM | #10 | ||||
Cuban... nothing like it
Some nice fiction there ssbaby, cheers :
09-09-2005, 12:02 PM | #11 | |||
Whipple Induced
mmm...interesting.;)
09-09-2005, 12:10 PM | #12 | ||
Judging from the overwhelmingly negative response, I reckon we scrap the rumourmill section as it seems it will open up a can of worms.
Rep Power: 0 |
09-09-2005, 12:33 PM | #13 | ||
I 100% believe it, and it will run on LPG, with an electric turbocharger and 6 hi clones, and will have a mid corner speed tio die for.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
09-09-2005, 12:54 PM | #14 | |||
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
09-09-2005, 12:55 PM | #15 | ||
There's a point of deminishing returns where KW per Litre of capacity is reached in an engine that a) has to pass strict emission regs, b) has to be user firendly and have good manners, c) has to be fuel efficient and d) can cope with vastly changing climatic conditions without compromising a) b) and c).
Effectively this is controlled heavily by the optimum air to fuel ratio being reached and quantity of fuel charge that enters the cylinder on each cycle. For the N/A motors: Boss 5.4 is at 53.7 kw/l, LS2 is at 49.5 kw/l, Forced: F6 is at 67.5 kw/l. XR6T is at 60 kw/l. The air to fuel ratio won't significantly change from N/A to Forced however the voulmetric efficiency does hence the extra kw/l. To put it simply it would be extremely difficult to get 60-70 kw/l form a N/A motor in a street car, 50-55kw/l seems to be about the limit with current tech.
335 S/C GT: The new KING of Australian made performance cars.. |
09-09-2005, 12:56 PM | #16 | |||
It will never happen!
09-09-2005, 01:03 PM | #17 | ||
Does sound unbelievable, but It'd bloody awesome if it did happen. Still if it did, a little out of my price range
09-09-2005, 01:04 PM | #18 | |||
09-09-2005, 01:05 PM | #19 | ||
Has Blue Blood
Mr sparkle, have you thought maybe this car is being built for santa clause and the tooth fairy to in response to the cityrail timetable ??????
it wont be for the yeti . Have you ever met a yeti with a licence ????? : :
Real cars dont wear bowties I'm not arrogent , Just superior
09-09-2005, 01:06 PM | #20 | |||
AFF's 1st DM.......
MMMmmmm V10..
Now theres a can of worms
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
09-09-2005, 01:08 PM | #21 | ||
As far as i know there are no new large displacement V8 engine developments from ford, the most recent being the 'hurricane' prooject, which has been canned.
The next engine lineup for Orion will be in production right now, the 5.4L all alloy s/c V8. There may be some configuration changes, but i believe this is the only engine Ford will have to choose from, makes sense from a cost and packaging point of view. |
09-09-2005, 01:18 PM | #22 | ||||
09-09-2005, 01:19 PM | #23 | |||
09-09-2005, 01:32 PM | #24 | ||
Honda S2000 - 176kw from NA 2L = 88kw/L
Isn't there a BMW model with over 100kw/L?
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
09-09-2005, 01:37 PM | #25 | |||
09-09-2005, 03:15 PM | #26 | |||
09-09-2005, 03:50 PM | #27 | ||
Formerly Black EX-R6
400kw base model production falcon
Whats the performance version going to be? 500kw. 600 maybe.
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly." Stinking, mongrel, dog. |
09-09-2005, 03:54 PM | #28 | ||
not here much anymore
Well, I wont bag it but I wont believe it just yet either.
RAM 1500
09-09-2005, 04:01 PM | #29 | |||
09-09-2005, 04:03 PM | #30 | ||
Two > One
Forgot to flush. My bad.
