#31 | ||
wow this is interesting thanks for all the info, it looks like a need to brush up on my nissan and holden knowledge.
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build. http://www.fordforums.com.au/showthread.php?t=11349360 Weekender: '69 VW Notchback http://www.fordforums.com.au/showthr...24#post4531824 |
#32 | |||
http://www.ebay.com.au/itm/JDM-R32-G...item58936f52f0 |
#33 | ||
In the latest unique cars issue, there is a base VL with only 12000kms, price $7500 firm
#34 | ||
Resident F1 Troll
rb26dett theyre never made rb20dett.
rb20's are pretty much useless not enough torque |
#35 | |||
Resident F1 Troll
#36 | ||
Had a number of VL calais, still have a calais 5ltr which i restored. The 6's were a great engine, common for head gaskets but as mentioned that was due to poor maintenance/improper coolant fills. They actually had a bleeder bolt on top of the intake plenum which was used to remove any air pockets that remained in the system after flushes etc. Problem was the radiator sat below the level of the top of the head so if the car wasn't filled properly you could have a problem on your hands. I believe the 6's used the Jatco 3 speed auto with electronic torque converter lock up (commonly thought of as a 4 speed box) but the electronic lock up was prone to failure so might be something to check up on. Diff used on the 6's was the solid borg warner with the 25 spline 3.45 rear end which i believe used the same crown and pinion gear as many of the earlier Fords (E series I believe, possibly X series as well). Some other things to look for are rust at the bottom of the front window pillars, rust at the base of the rear windscreen, rust inside the boot spare wheel well, dash electrics were sometimes a nightmare, leaking exhaust manifold gasket (soot at the back of the firewall on cases left untouched), fuel pressure regulator were known to pack in (car would run between great and blowing black smoke, running rough and coughing its ring up), Airfloe sensors as well as crank angle sensors. You would know if any of the above were bung as soon as you tried to start the car up/ run for 10 mins. And whatever else you can typically find on a 25 year old car. Yes they had thier shares of issues but show me a car that doesn't. Overall it would be a great daily if in good condition and you could have it cheap, they are obviously not as comfortable as today's cars but still smooth and quiet for the age. Parts are still around and can be had for decent prices. Also easy to work on if your into that and they are not too bad on fuel provided you don't redline the thing every chance you get.
#37 | |||
Oo\===/oO
Still need all the work assosiated with plumbing a TT... RB30/25DET all the way.
#38 | |||
#39 | ||
Makes me think of the one i found in a backyard the other day with 43,000 klms.Yes im trying to buy it.
#40 | |||
#41 | |||
#42 | ||
as in chopped
-> Reading this signature was pointless <- |
#43 | ||
3..2..1..
id love a vl grp a, still might build a replica one day.
vl walky looks but with nissan turbo for grunt. not a bad package. |
#44 | ||||
#45 | ||
3..2..1..
even the rb20e powered vl's wernt too bad a ride. obviously not the most powerful in the world, but reliable as an axe.
#46 | ||
Flairs - Truckers Delight
I'd hazard a guess a lot of people in this thread would have never driven a VL.
Let me tell you this - they are rough. They are old, they have vague power steering and underachieving brakes. Their interiors are rudimentary, they have questionable electronics and they are old. Did i mention they are old? Unless you have a specific purpose for wanting to own one, don't. If you would turn your nose up at an XF, then turn your nose up at a VL.
#47 | ||
Resident F1 Troll
sorry but vl's **** all over xf's at leasl they had a v8
#48 | ||
3..2..1..
lol, i am a xf fan, but id rate a vl over an xf too.
choice of v8 or turbo, decent modern (at the time) engine... hero models to look up to... there was no performance model in the xf's. |
#49 | ||
RB30ET was a cracker
#50 | |||
Oo\===/oO
Plus, the DETT's used ceramic turbos, not valued highly for chasing big power...
#51 | |||
And I'd rather the ceramic turbo's than a wheezy RB25 Context was "Should I buy a VL?" Dare say you wouldn't want to spend too many $'s on one in this day and age, hence a cheap jap transplant. If you were going in intending to spend big $'s on a VL you'd be best to give it a swerve. |
#52 | |||
Fixing Ford's **** ups
Only mentioning problems they have. Choice of purchase is upto the prospective buyer
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
#53 | |||
Sounds like you're an old car hater.
#54 | ||
Formerly ST170ish
If you can get it real cheap and its in good nick it would be a good canidate for wrecking as good condish panels are getting thinner on the ground because most youngins love them and cant drive for ****...
#55 | ||
i personally think the RB30 was a great motor myself. yes there was the head gasket thing but if there looked after they genreally do last!! only problem i have with VLs is the young tools who thrash them. expect too see a bit of rust in some of them (is aproching 30 years old) I personally think body wise the previous commodores where built better, (VB-VK). thats from what i have seen, i have seen some pretty clean one sthou in saying that. its like anycar it comes down too how it was looked after. in terms of moding i'd go for the RB30. lots of parts avalible and in turbo form absoultly fly for a 25 year old car. the RB30 with a 5 speed box is what i'd go for if it was me. the autos with the non- turbo RB30 are a bit sluggish for my liking but will do for a daily driver if you wanted one for that. you'd probablly would find a SL, Executive cheap, Berlina and Calais expect too pay more especally the Calais.
#56 | |||
The one and only
Desireable? Yeah if you are 16 to 26 and want to paint it yellow, fit 'ceptors and a turbo Reliable? Yeah. Nissan made them a good motor, common issue being the MAF. IMO, I'f refer the XF (Fords answer to VL) with a mild 250 and 5 speed and 3.23 gears.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#57 | |||
Its the unknowledged who just put water in ,but that hasnt been drummed into people nowadays How many when their alloy headed cars run hot pour cold water straight in,dont let them naturally cool first Its an education thing , people arent educated on alloy heads properly Any alloy headed car i had ,temps were checked all the time , everything had to be top notch But any cast headed engine i had, gee most could run all day without water never had some many head /head gasket issues in my life till i had alloy headed cars Thats aside , The VL if bought for the right $$$, would be a great runabout,parts are everywhere,and usually cheap So makes for a cheapie car If its a purchase to make money , it would wanna be cheap To me there is no good VL,that said i could be given a holden ,but wont come in my yard... |
#58 | ||
BIG MEMBER ;)
My old man use to own one. Great car.
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
#59 | ||
Don't think I'd ever buy one, but VL turbo was basically the only new car that could spank my old carb'd V8s and 265 Hemis when I first got my P's .. it was a rare sight though. Should have a place in our automotive history as a real turning point. Once more populous injected V8s started to come online in the VNs, etc the old low-tech brigade were in trouble.
#60 | ||
Some of my fondest car memories were my Exec Turbo
I loved the no frills nature of it, wouldn't have swapped it for a calais if you paid me. Like a GS 5.0 today. Everyone runs them down for being sparse, but that's why I love them |
