Old 10-02-2021, 11:11 AM   #1
green73
Default Ford Capri V6 engines
I have 2 ford v6 engines in my shed. There engine numbers are ck17k940710 and the other one is ck17Lk94075c. Does anyone know what model these are out of?
Thanks,
Green73
green73 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2021, 12:09 PM   #2
simon varley
Default Re: Ford Capri V6 engines
this may or may not help
https://www.classic-ford.org/cfp/tm.aspx?m=89841
or this
https://fordforums.com.au/showthread.php?t=11418060
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2021, 11:25 PM   #3
Capriman
formerly ford3000gt
Capriman's Avatar
Thanks,
Green73
The first one has an error in that the 6th character should be a letter, which is the month built. If The 5th letter K is correct it is from a 1970 GT/V6. The C=UK sourced export ckd or completely knocked down kit. The K= Homebush, NSW,, where it was assembled. The 17=Capri GT/V6 and the last 5 numbers are the vehicles unique serial number.
The second one is a 1971 (L), February, (K) GT/V6 build, the other characters, CK17 are the same as above. Once again the number 94075 is the unique vehicle serial number and the last letter C=V6 Engine.
Cheers, Terry
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2021, 01:42 PM   #4
green73
Thanks,
Green73
Update
I went and checked the numbers again. I had one wrong, these are the numbers I’ve come up with.
CK17LK 94071C
CK17LK 94075C
Hopefully someone will have a car that owns one of these motors.
Last edited by green73; 12-02-2021 at 01:43 PM. Reason: Forgot to add some information
