19-05-2020, 01:07 PM | #1 | ||
Hi guys,
I recently purchased an FG XR6 turbo motor and along with it came a zf that was not attached and out of a different vehicle. I was told it was out of another turbo car he had but I don't particularly believe him due to the fact all of the stickers have been removed. So essentially is there a way to work out if it's a Na or turbo box without cracking it open to view clutch packs? Thanks guys, |
19-05-2020, 01:53 PM | #2 | ||
Peter Car
Are there any stamped serial numbers? Or something else that could identify it?
19-05-2020, 08:59 PM | #3 | ||
Got all the serial numbers but have no idea what they mean or how to decipher them
20-05-2020, 09:18 AM | #4 | ||
20-05-2020, 11:38 AM | #5 | ||
Isn't the zf in the turbo made in Germany, and the one in the NAs made in China?
20-05-2020, 01:25 PM | #6 | ||
Hi TNT.
Post the serial numbers. Somebody may be able to help. If XR Martin is correct, the prefix or something may designate the country of origin ? Cheers. Last edited by gutza; 20-05-2020 at 01:31 PM. |
20-05-2020, 03:05 PM | #7 | ||
Hi TNT.
Not sure if it helps, but the bar code should ? be the same ???? If you still have it on the box ....... Picture 3. https://www.ebay.com.au/itm/FG-XR6T-...-/261548411260 |
20-05-2020, 03:11 PM | #8 | ||
Peter Car
20-05-2020, 03:30 PM | #9 | |||
Hi Boss.
So potentially, he could still have a N/A box made in Germany ? Would the barcode help, or could that change with manufactured year ? Cheers. |
20-05-2020, 03:42 PM | #10 | ||
Peter Car
Yes could still be a german made NA box. Barcode is only good if it can be read by someone who knows what info it can give.
I'd try contacting ZF Australia and give them the serial numbers and see if they can help. |
20-05-2020, 03:52 PM | #11 | |||
Hi Boss.
Thanks. |
21-05-2020, 12:24 PM | #12 | ||
Hi guys, thanks for the info.
It's definitely a German box it's stamped on the side These are all the serials on the box: 6hp -26 0655444015208 1068 401 259 >AlSi9cu3ife< 2207-2 Thanks guys |
21-05-2020, 03:17 PM | #13 | ||
Peter Car
Highly unlikely anyone outside ZF would be able to interpret those numbers. You will need to contact ZF Australia and they might be able to tell you what they mean.
21-05-2020, 04:52 PM | #14 | ||
I can guarantee it is neither!
ZF is not an engine ; ) |
22-05-2020, 07:24 PM | #15 | ||
Thanks ill call them on Monday
26-05-2020, 11:04 AM | #16 | |||
George
Higher rating torque convertor, 280mm 297Nm in the Turbo and V8, and 260mm 278Nm in the NA. Last edited by BFIIGhiaZF6; 26-05-2020 at 11:14 AM. |
26-05-2020, 02:48 PM | #17 | ||
Peter Car
No it's not. The turbo and V8 boxes have extra clutch packs to start with.
04-06-2020, 08:32 AM | #18 | ||
Hi,
Did you figure it out with a phone call? Otherwise, you should be able to plug in the engine harness to it, connect a ELM327 adapter to the CAN pins, (via a spare OBD plug), power up the TCM inside the trans with 12V, and use Forscan to read out the VIN. Then you can ask a Ford dealer which vehicle it came out of. Cheers,
'11 FG Turbo '08 Territory SY RWD And some non-fords: E90 M3 build, '07 Rocket III, |
15-08-2020, 09:18 PM | #19 | ||
Yeah phone call sorted it, it's a turbo box. Thanks guys
16-08-2020, 10:58 PM | #20 | ||
Didnt the n/a ZFs have the plastic pans whilst the turbos and V8s gave the metal one?
16-08-2020, 11:04 PM | #21 | ||
PURSUIT 250
19-08-2020, 10:32 PM | #22 | ||
6HP26 were for V8 and Turbo's and German as some have said
There was a difference in the bell housing between the turbo and 8 |
