ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
Hi guys,
I want to get your upgrade done to run RCA's and trigger wires for me stereo, but I have a problem with the way it runs at the moment. Currently I have high to low coverters running 2 amps. I think I have a short somewhere or loose wires because the speakers keep shutting off. If I crank the volume they come back on line. Is there any way you can check the unit for any problems prior to doing the upgrade? I don't want to get it done to find out the unit is dodgy and have the warranty void. |
#2 | |||
Sponsor
Come down one day and will check it for you, we have to remove and check for you. Sounds like it is shorting somewhere and its going in protective mode thats why we don't recommend high to low convertors cause you might blow up the ICC unit, and become very costly to repair. Cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
Thanks.
I will try and get there Friday. How long will it take to fit the upgrade if I hang around? And how much? I need to run 2 amps. One 4 channnel for 4 speakers and one mono block 2 channel for 2 subs. |
#4 | |||
Sponsor
We need the car for about 2 hrs, but please if you are coming for sure call us 1 day before so we can book you in. 039588 2755 or email me fadi@asllogistics.com cheers fadi75
