22-07-2005, 12:33 AM | #91 | ||
At last, you came to your senses!
HP/L has a similar relationship to BMEP. Do a bit of number crunching and you'll see why. I was simply cheating a little to avoid confusion (and yes, hoping you woudn't notice :P, well done...). PS, I've lurked FF for years. Just letting you know... |
22-07-2005, 12:36 AM | #92 | |||
LPG > You
LPG Lovers Association President & Member #1. : |
22-07-2005, 12:41 AM | #93 | ||||
Power = energy. Energy must be spent to turn the turbine. It isn't free, there is ALWAYS a loss... Get a tank of compressed air large enough to supply 6psi to an XR6T engine running NA headers (to an NA exhaust, no turbine involved, just free boost from the tank) for an entire dyno run and see if it produces more power or not... You'll find that its something like 20kw or so. Its allot harder to compress air than you think... Pressure isn't everything, volume is. Big difference. [EDIT] In reply to the post following (i don't want to post again, I'll just edit this one). The people who provide these calculators are taking a different angle. Clearly what they are saying is true, otherwise the gains made wouldn't be worth the cost (loss). My above example is a different angle, a basic energy cost example. If you didn't have to compress the air; if you could get boost for free, you would make massive numbers. Infact, infinitely large numbers as this is a form of perpetual motion, free energy. I know this isn't what you are thinking, but I'm taking it to this extreme to clearly get the point accross. That is, energy must come from somewhere... Also, the power stroke cylinder pressure in a performance engine is over 100psi.... (up to and over 1000 psi infact). Adding another 6psi to the next cylinders intake stroke isn't going to make all that much of a difference in combatting the losses in exhaust efficiency when using a turbo. Last edited by Lawsy; 22-07-2005 at 01:13 AM. |
22-07-2005, 12:47 AM | #94 | |||
LPG > You
http://www.turbocalculator.com/turbo...ercharger.html
23-07-2005, 10:47 AM | #95 | ||
Bring back Ambrose!
And what your arguing about is going to drastically effect your lives in what way?
24-07-2005, 07:41 PM | #96 | ||
FTF Club Moderator
What about the Bugatti Veyron engine a W16.
* The engine has four valves per cylinder, for a total of 64 valves. * It has a dry sump lubrication system borrowed from Formula 1 race cars, along with an intricate internal oil path to ensure proper lubrication and cooling within the 16 cylinders. * It has electronically controlled, continuously variable cam timing to create optimal performance at different engine rpm settings. * It has a massive radiator to deal with all of the waste heat that burning 1.33 gallons of gasoline per minute can generate. Everything about the engine is superlative. And it is remarkably compact. It measures just 710 mm (27 inches) long, 889 mm (35 inches) wide and 730 mm (28.7 inches) high. This is the beauty of Bugatti's W-16 approach -- the engineers managed to fit 1,000 hp into a reasonably sized package. Check out these sites: http://money.howstuffworks.com/bugatti1.htm http://www.forbes.com/2003/09/02/cx_mf_0902vow.html |
24-07-2005, 08:14 PM | #97 | ||||
No longer driving a Ford.
26-07-2005, 12:58 AM | #98 | ||
Brain stuck in neutral
http://rapidshare.de/files/3336628/TG_M5E60.wmv.html - Top Gear reviews the E60 M5
Steffo, I was wondering why a good road test with an AMG and M5 hasn't really happened yet.. I've concluded that it's really due to 2 reasons... That the AMG's are doughy, lardy, over-powered and under engineered average drivers cars... And that M5's aren't really available because they're too busy being compared with precise, purpose-built sportscars like the Porsche 911 Carrera S and Ferrari F430... And beating them... You're saying that almost every car reviewer, journalist and even Mercedes fans are wrong and you're the only one that's right??? I don't think so son...
Currently: 2006 VW Golf GTI Formerly: VYII SS VTII Calais |
26-07-2005, 05:10 PM | #99 | ||
Digging for avatar
Steffo , did you miss out on breast feeding?
was extinct but got better. |
26-07-2005, 07:07 PM | #100 | |||
LPG > You
27-07-2005, 12:06 AM | #101 | ||
So you have driven one and pushed its limits? Or just sat in the baby chair on the back seat?
27-07-2005, 12:15 AM | #102 | |||
LPG > You
However.. you don't need to do to much to realise how awesome the car is.. just pull out to overtake someone and you'll get the picture.
27-07-2005, 01:51 AM | #103 | |||
27-07-2005, 11:44 AM | #104 | |||
27-07-2005, 12:38 PM | #105 | |||
LPG > You
27-07-2005, 01:20 PM | #106 | ||
The 560 only weighs 1800kgs, heavy for the late '80s tho. Still, the awesome straight line performance of that car doesn't give one indication that it will handle good, and it doesn't, so its defiantley not a good all round car, unlike an M5, or any 5 series over 3.0L.
I think it was PCOTY 03 where the 235kw CV8 lapped winton quicker than the E55. Not that lap times tell all, what I meant with the E28 was that it would be a drivers choice rather than the E55. The 'Ultimate Driving Machine' motto wasn't pulled outa someones **** for no reason at all, or because of one specific model. Last edited by smoo; 27-07-2005 at 01:29 PM. |
27-07-2005, 01:22 PM | #107 | |||
LPG > You
27-07-2005, 02:29 PM | #108 | |||
starter motor
27-07-2005, 02:52 PM | #109 | |||
starter motor
27-07-2005, 03:44 PM | #110 | ||
LPG > You
Did anyone watch that Top Gear video? The M5 lapped their track in 1:26.2, the CLS55 AMG did 1:26.9. They're not THAT far apart.. would come down to driver.
What I want to see if the M5's V10 in the M3.. now that would move...
27-07-2005, 04:07 PM | #111 | ||||
RIP...
Rik.
. Oval Everywhere... |
27-07-2005, 04:24 PM | #112 | ||||
LPG > You
27-07-2005, 04:55 PM | #113 | ||
From what I've seen on Top Gear, I wouldn't take their times seriously, especially when some are done when its ****ing down and he can't keep the **** straight. Actually he gets it loose on every test, wet or dry.
Like I said lap times don't tell all. What do yoiu think would be a better, more rewarding drive between an MX5 or Elise v a Viper or CL65 etc. Sure the last two will be faster but I'd bet they're dogs in comparison. |
27-07-2005, 05:22 PM | #114 | ||||
RIP...
Rick.
Thread Tools | |
Display Modes | |
