11-12-2020, 01:44 PM | #61 | |||
Peter Car
But Australia does have the highest UV ratings anywhere in the world, so our sun is particularly harsh. |
11-12-2020, 01:49 PM | #62 | ||
Virtuous Bogan (TM)
By 00's I am thinking this does not include AU's, it simply can not. In all honesty IMO it was the car that had the highest build quality out of the lot.
How they are treated 20 years down the track is another story.
11-12-2020, 01:52 PM | #63 | ||
Peter Car
They did rust, and you see them all the time with clear coat peeling off. But yes, a lot of that comes down to how they are looked after, and if the owners ever bothered polishing them.
11-12-2020, 02:34 PM | #64 | |||
Chillie is a funny one as parts of it are so dry things dont rust, despite the paint peeling off
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP Last edited by Vesper Martini; 11-12-2020 at 02:47 PM. |
12-12-2020, 12:54 AM | #65 | |||
Yes, can confirm. My ford is a BA ute in shockwave. I have had to paint panels as they get unbearable to live with. I've resprayed the RHS(drivers) door, b pillar and guard, plus the entire roof. There's failure points on the bonnet, pass door and b pillar - each has a peeling spot that I just touched up with a brush. Just this year the LHS (pass) b pillar is getting worse and worse. Lets just say I wouldn't dream of ever ever pressure washing it because i can see already where it's going to let go if I did. that said though, the never fully repainted LHS ( pass) side can still shine up OK. The primer sucks but the clear coat doesn't suck. The clear coat done on the canopy sucks though! Photo from this year: https://i.imgur.com/35BgB35.jpg Bare in mind that's it's best 'factory' side - the entire roof failed, and the drivers guard and door were very very bad. But circled in yellow in where it is failing elsewhere, bonnet on the drivers corner, a bit on the pass door and the b pillar there is really bad. Meanwhile the clear coat on the canopy is completely stuffed. It was never good but this was parked in the sun for forever - including 2013-2019 where it was never driven, let alone washed Last edited by oldel; 12-12-2020 at 01:08 AM. |
12-12-2020, 04:39 AM | #66 | ||
12-12-2020, 04:43 AM | #67 | ||
Looks like metal to me, but it's not silver as you'd expect because it's been "stained" by the paint. But the actual paint is pretty much gone. The clear coat itself is a very thin layer. If it comes off, the paint underneath won't look like that - you can see that a thick layer has come off just by looking at it. It looks like the clear has come off first, then the actual paint underneath has soon followed due to having no protection.
12-12-2020, 11:09 AM | #68 | ||
Oppressive patriarch
That may be so, but ive never understood why. Mitsi took over the Chrysler factory, knew local conditions and built cars here, for here. It makes no sense.
. Lamenting lost Australian manufacturing. |
12-12-2020, 05:18 PM | #69 | ||
Yep, XT engines were labelled as 3.1 and 3.6L for the sixes. I think that continued with the XW? Mustang 5 Litre was how the V8 was marketed I think.
188/221/302ci Back on topic - aaargh those door window switches and windows getting stuck. Just siliconed the Terry, drivers window is near shot in movement. It's a big window... Tbh, would rather have a car with wind-up windows as it ages... On the bright side, no opening drivers' window = can't do Maccas drive through = less obesity
I6 + AWD |
12-12-2020, 08:47 PM | #70 | |||
Where to next??
12-12-2020, 10:19 PM | #71 | |||
Peter Car
12-12-2020, 11:37 PM | #72 | ||
paint supplier (PPG) got it wrong, doesn't stick to the primer used by ford.
My tub was fitted later (white au tub chucked on a formerly tray back ba 1 tonner ute) and resprayed by ford when it was resold and the tub never peeled off. Bad spray directly over white with no primer but didn't peel of at least. |
2 users like this post: |
13-12-2020, 08:24 AM | #73 | |||
It’s not as if Aussie cars from the last twenty years have stood up to these conditions, unless they’ve been kept inside. paint fade on AU-FG, Terry and VE. headlight oxidation on the same above. Haven’t notice it as much in FG though. Hood lining sagging is common on them as well after 15 years. Standard spec has no external trans cooler on them. territory and B series rust issues less than five years from new. In a country where 85% of the population lives within 50km from the coast. Territory and B series ball joints. Control blade IRS bushes. Most of the later models come with larger alloys and low profile tyres. Falcon seat bases that collapse within 100,000km, giving the driver a dead **** on a drive longer than going down the road. Weak seat bases in a country that ranks 6th in obesity OECD. |
3 users like this post: |
13-12-2020, 08:36 AM | #74 | |||
Cabover nut
Funny enough all basecoat white in colour. I feel for Hayseed with the red (pink) fleet.
4 users like this post: |
13-12-2020, 07:31 PM | #75 | ||
You could probably treat yourself to an EL Ghia as well Rokwiz (even tho electronic), those seem safe?
+1 on the pre electronic, just imagine the electric VWs as they age...
I6 + AWD |
13-12-2020, 07:41 PM | #76 | |||
Thailand Specials
15-12-2020, 08:42 PM | #77 | ||
Excellent, that means I could use it to also power my Lunar Command Module.
I6 + AWD |
15-12-2020, 08:55 PM | #78 | ||
Thailand Specials
15-12-2020, 09:14 PM | #79 | ||
Thanks, that was incredible. What a legend engineer.
5:50 : "Unreliability, that's the key... because the more cores you add... the more unreliablilty you add to your system because of sheer numbers of parts." Also, those bits, individually hand-wound, polarity was either 1 or 0 - they fit a program in the memory they created to guide the rocket through it's entire ascent! Then they built triple redundancies in the guidance and double redundancies in the memory. Epic.
I6 + AWD |
16-12-2020, 12:47 AM | #80 | ||
No one has mentioned the biodegradable wiring insulation that various Mercedes' had in the '80s and '90s.
16-12-2020, 12:07 PM | #81 | ||
wow how far we have come, they really were flying blind back then took them 2 weeks to analyze the data from spreadsheets!
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
16-12-2020, 12:18 PM | #82 | ||
When you think about it, it's absolutely amazing they did* what they did with the technology on hand.
*some may believe it's impossible to fly through the firmament and leave the flat plane
I6 + AWD |
16-12-2020, 12:21 PM | #83 | ||
20-12-2020, 08:15 PM | #84 | ||
A modern Hilux has more computing power than the Saturn V's and I saw one such Hilux of Friday using all of it's computer power to lay a glorious smoke screen over everyone behind them at the traffic lights.
Joke of an engine management system
I6 + AWD |
21-12-2020, 08:28 AM | #85 | |||
Nearly all will have been replaced by now, unless it’s a low mileage example kept in the garage all it’s life. Those engines the harnesses were fitted to are solid. The same can’t be said for the petrol ones developed post 2000 which are made of cheese. |
21-12-2020, 12:50 PM | #86 | |||
Former BTIKD
21-12-2020, 02:00 PM | #87 | ||
21-12-2020, 03:07 PM | #88 | ||
Former BTIKD
Yeah, mines an M112 V6, (but 12 spark plugs Coz Benz ) will clock over to 300,000 kms in the next week
21-12-2020, 03:21 PM | #89 | ||
21-12-2020, 03:30 PM | #90 | ||
Former BTIKD
CLK240 the one in my Avatar.....minus the Bullbar
Thread Tools | |
Display Modes | |
