12-10-2009, 11:02 AM | #1 | ||
Just another mock-up..
Hey guys, just a quick one..
How do you remove the passenger Air Bag on the Fairlane.. I can see that its under a cover, but, how do you remove the cover..? Do i pull from a corner?? Any help appreciated.. Cheers kris
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
12-10-2009, 01:33 PM | #2 | ||
When in doubt, GAS IT!!
I don't know about AU but if it's anything like EF-EL then the cover is just a press fit with 4 posts into rubber grommets. The cover will be connected to the bag assembly with webbing straps and the whole lot unplugs from the loom and is held in with a couple of bolts. If you drop out the glove box you should be able to get up inside the dash facia and push it out from there, failing that, I used a putty knige with a towel under it to coax my EF one off.
Bushbasher
12-10-2009, 01:36 PM | #3 | ||
Lost Boost Gained Class
its only held in with a glue type of stuff i removed one from a S2 Ex taxi for a mate about 4 months ago Kife sould do the trick
2006 BF Fairmont Ghia
2001 AU Falcon |
12-10-2009, 01:49 PM | #4 | ||
thanks guys... i'll have a crack at it..
should i pull from the top down?
12-10-2009, 04:09 PM | #5 | ||
They are held by 4 clips - with a wide blade like a paint scraper you can just prise the air bag cover out - the clips will break as you do so. Because some people are too scabby (esp taxi drivers) to buy new clips for less than $3 each, they replace the cover with glue/silicone/etc. Once the cover is off the whole air bag will simply lift out by hand - no tricks here. But DO make sure you disconnect the battery before removing cover.
12-10-2009, 04:11 PM | #6 | ||
You'll find the cover is attached with for little plastic posts which when you pull it off will break. Then there are four 10mm bolts holding the whole assembly in place. I don't think you can get it out without breaking the white clips. They just locate the cover until it deploys and then they break as planned. The cover should just sit back in without a problem though maybe just use a bit of blu tac to hold it in place.
Cheers, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
12-10-2009, 09:16 PM | #7 | ||
thanks heaps guys.. you all helped alot..
went to ford and got the clips.. it's all done now.. was alot easier than i though... cheers for all the help....
18-11-2020, 10:12 AM | #8 | ||
Can get new clips here
https://www.ebay.com.au/itm/Ford-AU-...kAAOSwW6hfmVQ1 |
